Motor shake
Old Sep 6, 2016 | 11:18 PM
OneEvlZ's Avatar
OneEvlZ
Cruising
Default Motor shake
My car has a pretty aggressive cam. Every so often when I'm at idle the car shake like crazy then goes back to normal. Is that normal or should I check out my motor mounts maybe?? Thanks guys
Old Sep 6, 2016 | 11:48 PM
StingrayRebel's Avatar
StingrayRebel
stock mounts suck in my opinion, my motor shook with the stock cam... I put in a set of pfadt mounts and now it's rock solid and the power delivery also felt much smoother... I really like their design but after the way they treated their customers a year or so ago I am reluctant to recommend them anymore... there are some other companies making them now that essentially copied that design, fabberge is one and I believe lmr was making them as well
Old Sep 7, 2016 | 12:34 AM
OneEvlZ's Avatar
OneEvlZ
Cruising
awesome. Thanks bro. Gonna def grab some and check out those brands. Appreciate it!!
Old Sep 7, 2016 | 09:57 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I would also examine the rear differential mount. If the front mounts are bad, it puts a LOT of stress on the rear mount under heavy loads.
Bill
Old Sep 7, 2016 | 01:01 PM
Aaron at SDPC's Avatar
0Aaron at SDPC
Former Vendor
Pretty common occurrence with an aftermarket camshaft and stock mounts.
To Motor shake
