Slight Vibration… looking for suggestions
Old Oct 14, 2016 | 09:00 AM
K-Spaz's Avatar
K-Spaz
From: Central PA. - - My AR15 identifies as a muzzleloader
I believe in the Beer Fairy
Engine mounts caused a "vibration", or a clunk?
I'd still say you have a balancer job in your future. :leaving"
Old Oct 14, 2016 | 09:29 AM
Joshboody's Avatar
Joshboody
Never a clunk like I expected after researching failed mounts online. One mount got to metal on metal (inner cage). They had to be bad for awhile but only recently started vibrating.
The way to tell is rocking the engine by hand. I did this awhile ago, but didn't have any comparison... now I do.
Old Oct 14, 2016 | 10:04 AM
K-Spaz's Avatar
K-Spaz
So basically you had something similar to solid mounts once the rubber let go? Hmm, never heard of such a thing. Learn something new every day I guess.
I suppose I could say I have something similar. I just put in poly suspension bushings, and they tend to transmit a lot of road/engine noise into the cabin as well. With them though it's easy to tell what's causing it.
Did your shifter move substantially? I would think you'd notice it in that when the TT moved.
Old Oct 14, 2016 | 12:25 PM
Joshboody's Avatar
Joshboody
Thinking back likely more drivetrain movement but not very obvious. Not solid at all, mounts have inner cage 2 metal links hooked together inside the rubber but with lots of play once rubber gone.
