I would like to know what this codes mean I have 1997 it seems that my volts seem to run in the 11.5 to 12.4 when I drive but when I start the car it is at 13.4 any advise thanks.
I also do not know what your three codes mean but I will respond to keep the thread alive. Are your codes History or Current, H or C? History codes often are of little use in diagnosing a problem.
The first code is p1518 C H the next is p1571 H and c1278 C I have Cartek H/C the car runs good but the reduce engine came up on DIC I cut the car off and it drove fine cleared codes and hasn't come up all night while I was out I think I need to take it to the dealer.Can't have the vette on the side of the road.
The 1518 means that you have a fault related to the "drive by wire" and thats why the "reduced power" mode comes on...Possible causes are a faulty TAC module,accelerator APP sensor,or TAC motor,or related connections...The 1278 simply means that the ABS traction control was inhibited (shut down) while the PCM fault was detected...
REDUCED ENG. POW. MESSAGE ALONG W/ PARTIC. PWRTRAIN #87-65-16
SUBJECT: REDUCED ENGINE POWER MESSAGE ALONG WITH PARTICULAR POWERTRAIN TROUBLE CODES (INSTALL NEW TAC-MODULE IF STRATEGY IN SERVICE MANUAL FAILS)
MODELS: 1997-98 CHEVROLET CORVETTE WITH 5.7L V8 ENGINE (VIN G - RPO LS1)
CONDITION #1: INTERMITTENT REDUCED ENGINE POWER EVENT, ACCOMPANIED BY P-1516, OR P1518 TROUBLE CODES.
IF A SITUATION ARISES WHERE A P-1516 TROUBLE CODE IS ACCOMPANIED BY A
P-1120 AND/OR P-1220 TROUBLE CODE, THIS SERVICE BULLETIN DOES NOT ----------------------------------------------------------------- APPLY. IN THESE CASES THE TECHNICIAN MUST USE THE NORMAL STRATEGY ------------------------------------------------------------------ BASED DIAGNOSTIC. -----------------
CONDITION #2: INTERMITTENT REDUCED ENGINE POWER ACCOMPANIED BY TROUBLE CODE P-1125 AND ANY OF THE FOLLOWING TROUBLE CODES:
P-1276 P-1281 P-1286
CAUSE:
CONDITION MAY BE DUE TO DIAGNOSTIC SOFTWARE AND CALIBRATION IN THE TAC-MODULE WERE NOT OPTIMALLY UTILIZED.
CORRECTION:
IF THE ABOVE CONDITIONS CANNOT BE CORRECTED USING THE NORMAL STRATEGY BASED DIAGNOSTICS LISTED IN THE SERVICE MANUAL, INSTALL THE NEW TAC- MODULE LISTED BELOW.
PART INFORMATION:
NEW TAC-MODULE PART # 25319443
PARTS ARE EXPECTED TO BE AVAILABLE ON APRIL 6, 1998 FROM GMSPO.
