Dyno reading help
Old Sep 14, 2002 | 10:33 PM
tonyh2000's Avatar
tonyh2000
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
St. Jude Donor '03
Default Dyno reading help
Had my car on the Dyno today for the 1st time. It is a 2000 with about 32k miles. It was getting lots of spikes. Was told I needed new plugs and wires. Maybe someone could take a look and tell me what I need to do to correct it. Dyno run was done at about 9:15 am so it was not real warm out yet.
Only mods are Blackwing and Corsa exhaust.
Thanks for any help on this.
Old Sep 14, 2002 | 11:19 PM
99NassauVette's Avatar
99NassauVette
Default Re: Dyno reading help (tonyh2000)
looks like its time for a plug and wire change! :yesnod:
Old Sep 14, 2002 | 11:49 PM
90 droptop's Avatar
90 droptop
Default Re: Dyno reading help (99NassauVette)
Old Sep 15, 2002 | 12:01 AM
tonyh2000's Avatar
tonyh2000
Cruise-In V Veteran
St. Jude Donor '03
Thanks for the info, now the next questions.
Which plugs and which wires, lots to choose from?
Old Sep 15, 2002 | 12:40 AM
Snake Slayer's Avatar
Snake Slayer
Cruise-In V Veteran
Tony, NGK tr55's and Taylor Thundervolts.
Old Sep 15, 2002 | 01:52 AM
Xssesive's Avatar
Xssesive
Default Re: Dyno reading help (Snake Slayer)
I've tried to tell others here on the forum that the factory plugs and wires are not very good and they sure don't last long. My 98 had no platinum pucks left at 37K miles and the wires were causing mis-fires on Autotap. With your mods the NGK TR 55's should work well(find them at O'Reillys Auto Parts) and Taylor Thundervolts or Magnecor wires work good. PS you might want to try a slightly smaller gap with the new plugs .050 seems to work good and keeps the knock retard down.
Old Sep 15, 2002 | 03:40 PM
Steve02C5's Avatar
Steve02C5
From: Renaissance Festival TAZ the Wolfdog (R.I.P.)
FWIW, Jayson at MTI told me the dynojets have a "smoothing" ability which will smooth out the curves.
To Dyno reading help
