I have a 2002 Red C5 with both top options. I have just over 18K miles on it and love the condition it's in. During the winter months it's stored in my garage and covered with a thick, tight fitting custom cover. Prior to covering the car for the winter, I pop all of the seals to keep them from getting a permanent compression. This may be unnecessary with modern materials but it's an old habit. This spring I noticed a very small tear in the door seal right where the tops and the door meet. When I go through the touch-less car wash I have to make sure that seal is positioned just right otherwise I get a small amount of water come in during the spray cycle. The tear is so small that I could reseal it if I used the right material. I don't want to replace that seal. Is there a recommended glue, etc that can be used to fix? Thanks in advance!
I used this to fix a tear in my weatherstripping. I developed a tear on the verticle passenger side part right where it meets the targa top. Two years and still going strong.
