Rear Differential Fluid Choice???
Old Sep 15, 2002 | 06:01 PM
C54FUN's Avatar
C54FUN
St. Jude Donor '03-'05-'06-'08-'10
Default Rear Differential Fluid Choice???
Thinking of changing my fluid in the rear of my '98. As I am seeing some track time, was thinking about replacing it with other than the stock fluid; are there others I should consider? Appreciate the help and thanks.
Joe
[Modified by C54FUN, 4:04 PM 9/15/2002]
Old Sep 15, 2002 | 08:19 PM
carpe dm's Avatar
carpe dm
Default Re: Rear Differential Fluid Choice??? (C54FUN)
I chose Amsoil Synthetic 75-90W gear oil. It has the limited slip fluid in it. Mobil 1 synthetic and RedLine are good too. :yesnod: :)
Old Sep 15, 2002 | 09:47 PM
JWD01's Avatar
JWD01
Default Re: Rear Differential Fluid Choice??? (carpe dm)
AMSOIL :yesnod:
Old Sep 16, 2002 | 04:42 AM
Richin Chicago's Avatar
Richin Chicago
Redline.
Old Sep 16, 2002 | 04:44 AM
Mike Schriber's Avatar
Mike Schriber
I use Mobil 1 synthetic and a bottle of GM friction modifier.
Mike :flag
Old Sep 16, 2002 | 05:57 AM
vettenuts's Avatar
vettenuts
Default Re: Rear Differential Fluid Choice??? (Mike Schriber)
Amsoil here also.
Old Sep 16, 2002 | 03:04 PM
Rob 2K1's Avatar
Rob 2K1
Default Re: Rear Differential Fluid Choice??? (vettenuts)
Redline here.
You really can't go wrong with any of the synthetics. Both Redline and Amsoil have the friction additive for the limited slip diff included. With Mobil 1 you will need to add some.
-Rob
Old Sep 17, 2002 | 01:14 AM
NastyC5's Avatar
NastyC5
Royal Purple :yesnod:
Old Sep 17, 2002 | 08:35 AM
YO-EL's Avatar
YO-EL
Default Re: Rear Differential Fluid Choice??? (NastyC5)
Amsoil here in my rear....
Old Sep 17, 2002 | 10:42 AM
Richin Chicago
Default Re: Rear Differential Fluid Choice??? (indypace78)
What a mess that must of been! Did it hurt?? :p: :p:
Old Sep 22, 2002 | 02:16 AM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Default Re: Rear Differential Fluid Choice??? (Richin Chicago)
GM also makes a synthetic diff fluid, which is what the cars have been factory filled with for a couple of years. Seems to work great for me, and I get a free fluid change every year when the dealer has to re-re-seal my diff when it starts to leak again :eek:
One of the techs has reported that some cars will start to experience the grinding/snapping/popping noise in the rear end a few thousand miles after switching to any synthetic, whether or not the synthetic has friction modifier in it already or whether the GM modifier is used. If that happens, switching back to GM non-synthetic seems to solve the problem. This only happens on a few cars, and mine is not one of them :)
Old Sep 22, 2002 | 03:28 AM
evil-1's Avatar
evil-1
Default Re: Rear Differential Fluid Choice??? (Gearhead Jim)
....... :yesnod: Redline :yesnod: ........
Old Sep 22, 2002 | 11:41 AM
01c5z06's Avatar
01c5z06
Default Re: Rear Differential Fluid Choice??? (evil-1)
Redline
To Rear Differential Fluid Choice???
