what spark plugs do u use
Old Sep 16, 2002 | 01:43 AM
tito's Avatar
tito
Default what spark plugs do u use
Im about do change out plugs thinking of going with something a little different. Has anyone tried out the Denso Iridium's?
Old Sep 16, 2002 | 09:55 AM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
Default Re: what spark plugs do u use (tito)
The Denso is a factory plug. Just took them out of my car at 25,000 miles they looked great. I did put in the AC Delco Rapid Fire plugs and new RED factory wires. Quite honestly the car ran great before and still runs great now. :D
Bob
Old Sep 16, 2002 | 12:36 PM
luvinc5's Avatar
luvinc5
Default Re: what spark plugs do u use (16Again)
I just changed over to NGK TR55 plugs. If you want longevity, use platinum tip plugs like the stock plugs. If you want performance (but lesser life), use the copper core plugs like NGK TR55.
Old Sep 16, 2002 | 05:35 PM
Joe's Eray's Avatar
Joe's Eray
Default Re: what spark plugs do u use (luvinc5)
How long does the NGK's last for? I just had them put in last Satuday. My car runs like a raped ape now. :jester
Old Sep 16, 2002 | 07:57 PM
Old Rotor Head's Avatar
Old Rotor Head
I change my NGK Tr55's out every 15k. Their cheap.
Old Sep 17, 2002 | 02:54 AM
tito's Avatar
tito
Default Re: what spark plugs do u use (Old Rotor Head)
im running juice so i currently have tr55's in my car.. would i benefit from tr6's?
Old Sep 17, 2002 | 09:29 AM
shftn6's Avatar
shftn6
TR6 for nitrous
Old Sep 17, 2002 | 09:42 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
TR6 for the Blower
vetterdstr :cheers:
Old Sep 17, 2002 | 10:34 PM
davidfarmer's Avatar
davidfarmer
Default Re: what spark plugs do u use (vetterdstr)
FR1LS Delco gapped at .050"
Old Sep 18, 2002 | 01:16 AM
TeamZ06's Avatar
TeamZ06
Default Re: what spark plugs do u use (davidfarmer)
I replaced the OE plugs with Bosch +4 on my Z06 and saw a top end improvement. The OE plugs only had 5,500 miles but with a lot of WOT autocross use. The factory gap on the OE plugs is wide enough to drive a truck through. The Bosch +4 plugs have side electrodes and do not require indexing or gapping.
IMO you should install new sparkplug wires with new plugs.
Mark
Old Sep 18, 2002 | 01:18 AM
turboo2u's Avatar
turboo2u
Beru Silverstones
Old Sep 18, 2002 | 01:40 AM
IrishMac's Avatar
IrishMac
Moderator Emeritus
Gone, but not Forgotten
Cruise-In 5, 6, 8 & 10 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09
I just installed the new NGK TR55 Iridiums and the Magnecor 8.5mm wires last weekend. I swear I can feel an improvement in response. I just hope the NGK's last a while, as I "forgot" to use any antiseize on them :crazy:
Old Sep 18, 2002 | 01:59 AM
droptop's Avatar
droptop
I put in Bosch +4 's. I could feel a difference. Its crazy, the stock ones looked very worn at 7,500 miles with only minor "hotrodding" :D
Old Sep 22, 2002 | 01:14 AM
nmbis2k's Avatar
nmbis2k
I pulled the stock ACs at 11,000. They looked fine. Replaced with NGK tr55 and MSD wires. DId so mainly to get some new plugs in before the old ones became tough to remove. New plugs call for only 11-12 foot pounds of torque, the old took at least 30 ft. pounds to break loss.
The car runs great, no notable difference before or after.
To what spark plugs do u use
