I'm stuck
Old Oct 12, 2016 | 09:37 PM
garebear's Avatar
garebear
Default I'm stuck
I removed the console to get at the HVAC control. Sent it away for repair. I would like to completely remove the console to repair the cup holder lid,but cannot get past the connector that goes to the "airbag off" light. It seems to be an uncommon connector at least I'm not familiar with it. It looks fragile, looks like either end can come off but I'm stumped. Two small wings on one end just fold over when squeezed. It has a metal clip that holds it to the cover, is there something under that I'm not seeing?
Old Oct 12, 2016 | 10:09 PM
zachaeous's Avatar
zachaeous
If memory serves me there is one side of the connector that will pry up just a little to clear a little locking peg and then it will release.
I will try and find a picture and add it here.
Old Oct 12, 2016 | 10:16 PM
WickedSilverC5's Avatar
WickedSilverC5
I had the same issue. Check out this thread.
https://www.corvetteforum.com/forums/c5-tech/3824413-removing-center-console-unable-to-disconnect-passenger-air-bag-light.html
Old Oct 12, 2016 | 10:48 PM
garebear's Avatar
garebear
Default I'm stuck
https://www.corvetteforum.com/forums...bag-light.html
Thanks for that link. I'll try that at first light.
Old Oct 12, 2016 | 11:26 PM
tommypenguin's Avatar
tommypenguin
That plug is a PITA, I've taken that panel off so many times and always dreaded that plug. I ended up snipping off the plug and using male and female connectors for the two wires to male it easy every time.
To I'm stuck
