Driver's door lock button doesn't work--replace relay or button?
Old Oct 18, 2016 | 05:14 PM
TastyBacon's Avatar
TastyBacon
Default Driver's door lock button doesn't work--replace relay or button?
Hey, hopefully this should be an easy one. The lock button on my driver's door has stopped working, but the doors will still lock via the button on the passenger's door or the remote. I've read about the relays in the door control module failing and that sounds like a job I could do myself, but when those fail, does the door stop locking via power entirely, or does it fail like mine has, where just the driver's door button will no longer lock the door. Not sure if I need to replace the button or the relay, and don't want to waste time and money replacing the wrong thing! Thanks.
Old Oct 19, 2016 | 01:31 PM
SilverC54me's Avatar
SilverC54me
From your description, you will need to replace the door switch.
If the door did not lock by the remote or switch on passenger door then it would be the relay in the door control module.
Gary
Old Oct 19, 2016 | 02:46 PM
TastyBacon's Avatar
TastyBacon
Ah, that's what I was afraid of. Thanks for the confirmation!
Old Oct 19, 2016 | 08:04 PM
SilverC54me
As I understand there is an aftermarket replacement for the drivers door control. The one made has the memory buttons on it.
Gary
To Driver's door lock button doesn't work--replace relay or button?
