Eradispeed Question
Old Sep 16, 2002 | 04:47 PM
NetJunkie's Avatar
NetJunkie
Default Eradispeed Question
I'm thinking of adding a set of Eradispeeds. I like the +1 look for the rears but I noticed on some pictures that they have a two-tone look after using them a while since the pad only hits about half the rotor. Is that normal? I don't really like it and may just settle for the stock sized replacements.
Old Sep 16, 2002 | 04:54 PM
Patches's Avatar
Patches
Default Re: Eradispeed Question (NetJunkie)
You'll get that using the stock calipers and pads because, although the swept area of the rotor increases, the stock pad still only clamps onto the outside portion of the new rotor, leaving the inner swept surface untouched.
This is the reason I stuck with the stock-size rear EradiSpeed. It doesn't look as cool as the larger rear rotor but I didn't want to do any more substantial changes to the brake system.
The +1's do look way cool though. :cheers:
Old Sep 16, 2002 | 05:29 PM
C5Longhorn's Avatar
C5Longhorn
Default Re: Eradispeed Question (Patches)
This is the exact reason I also went with the old system.
Old Sep 16, 2002 | 07:01 PM
NetJunkie's Avatar
NetJunkie
Default Re: Eradispeed Question (rschiltz)
Thanks guys. I just saved some money...to go elsewhere on the car. :)
I'll get the stock size replacements as well.
To Eradispeed Question
