Hinson Urethane Engine/Diff Mounts
Old Oct 23, 2016 | 05:05 PM
JD White's Avatar
JD White
Default Hinson Urethane Engine/Diff Mounts
I've done some searching looking for feedback on the Hinson urethane engine mounts, both the OEM and 3/8" shorter height and the diff mount but haven't found anything to convince me which way to go. I'm in the process of re-installing my driveline after a new clutch, driveshaft, and upgraded trans & diff in my '02Z. Since I'm already there I'd like to throw in the urethane diff mount and buy it as a set with engine mounts for later installation.
I will be picking up a Fast 92mm manifold so the 3/8" shorter mounts are appealing but looking under the car it appears that 3/8" shorter is really pushing the limits of how much the engine can be lowered. I'm very much inclined to go with the OEM height mounts but would like some opinions/feedback from anyone who's got them or seen them in action.
Thanks!
Old Oct 23, 2016 | 05:49 PM
outsideline's Avatar
outsideline
Default Motor mounts
Thanks!
Put them in my 02 Z with headers. No problems. You will need the clearance on top with the fast. No vibration, no overtorque & hitting hood.
I added dry sump & couldn't have run oil runs with stock.
It was a very good upgrade.
Old Oct 23, 2016 | 08:21 PM
Last C5's Avatar
Last C5
Did the same on my 01 Z with the same results.
Old Oct 23, 2016 | 11:33 PM
JD White's Avatar
JD White
Awesome, I'll go with the shorter ones then. Thanks for the quick replies. 👍
To Hinson Urethane Engine/Diff Mounts
