Changing Coolant
Old Oct 30, 2016 | 01:32 PM
bsmithC5/2004's Avatar
bsmithC5/2004
Default Changing Coolant
Trying to change coolant for first time in my 2004 . I can not get the drain plug to let the coolant drain. Turned 1/4 turn counter clock wise but nothing is coming out. Turned it bit until it stopped. Nothing happening. I was told to be careful or it would break . This is a plastic plugged and used a 1/4" drive to turn it. How do you know if you broke it?
Guess it sounds like I broke it. Can they be replaced easily or is this changing the radiator.
Old Oct 30, 2016 | 02:01 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
If you aren't the original owner of the car, and don't know the maintenance history, it's possible that the coolant hasn't been changed in a LONG time, therefore the plug is simply plugged/stuck. I'd try gently jiggling it around, when it's loose, and see if you can get the coolant to flow.
I just changed my coolant a couple of days ago, on my '01. Once I loosen the plastic piece you're referring to, the coolant drains out of a rubber "spout" that points down. If your car is like that, you might want to loosen the drain, and carefully poke a piece of wire, or straightened out paper clip, in this spout. Maybe there's some crud plugging it up.
Old Oct 30, 2016 | 02:24 PM
bsmithC5/2004
I am the original owner bought it new in 2004. It has 15000 original miles. The coolant looks really red and it was brought to my attention it should be changed.
The plug will turn about 3/4 of a turn and stop. I can turn it back 3/4 turn and it will stop.
Can the plug itself be replaced? Can it fall out when broken? Might be easier pulling the bottom rad hose?
Old Oct 30, 2016 | 02:29 PM
bsmithC5/2004
I already tried putting a piece of wire up the drain whole and really could not get it up very far. Not really sure of the position now after a 3/4 turn CCW. I cab turn it back 3/4 turn clockwise and it stops. It will turn 360.
Old Oct 30, 2016 | 05:40 PM
Thanks for the info. Will keep this on file in case I ever need to use it.
Old Oct 30, 2016 | 06:02 PM
K-Spaz's Avatar
K-Spaz
From: Central PA. - - My AR15 identifies as a muzzleloader
I believe in the Beer Fairy
Mine doesn't "Turn" out, I have to pull it. Turn it the 1/4 turn left, grab with a pair of pliers and pull. Should come right out. Fyi, there's no way I can pull it with my fingers. It's not much more than I could pull, but it ain't happening. Use pliers.
Old Oct 30, 2016 | 10:44 PM
foggy's Avatar
foggy
Turn and pull.
Also, you'll have to loosen / remove the cap on the tank..
To release the "suction"
Then it'll drain out real fast
Old Oct 30, 2016 | 10:56 PM
LoneStarFRC's Avatar
LoneStarFRC
Needle nose worked fine for me.
Old Oct 31, 2016 | 06:12 PM
Bill Dearborn's Avatar
Bill Dearborn
Wow talk about lack of maintenance, it should have been changed in 2009 and 2014. Dex is a great coolant but they tell you to change it every 5 years or every 150K miles which ever comes first.
Once you get the plug out and replace it flush the cooling system to get out all of the old coolant. That will take draining, refilling with water, draining again and refilling, repeating until the drained fluid runs clear. Once the drained fluid is clear water then add in half the cooling system capacity of pure DexCool and top off with water. That will get you to 50% mix of all new fluid. Not sure what damage would have occurred due to not changing the coolant as all of corrosion inhibitors and water pump lubricant they put in it are long gone but hopefully, the radiator, heater core, water pump bushing and the engine cooling passages haven't been damaged.
Bill
Old Oct 31, 2016 | 06:49 PM
leadfoot4's Avatar
leadfoot4
Bill
I didn't want to slam the OP, while he was attempting to do the right thing, but yeah, that was one of the first things that crossed my mind. I'd now say that the drain hole in the radiator is probably filled shut with crud.
Old Nov 6, 2016 | 11:31 PM
Sam Handwich's Avatar
Sam Handwich
Like some of the other posters are saying: Turn it until it stops and then pull it out.
Old Nov 7, 2016 | 05:04 AM
romandian's Avatar
romandian
turn it 1/4 turn and pull and wiggle. dont give up. initially i thought mine was plugged, but its not. its a 99, so im not sure if thre are plugs you need to turn until they stop.
Old Nov 7, 2016 | 08:35 AM
Sam Handwich
Originally Posted by romandian
turn it 1/4 turn and pull and wiggle. don't give up. initially i thought mine was plugged, but its not. its a 99, so i'm not sure if there are plugs you need to turn until they stop.
It is a bit finicky. Once I figured it out I thought it was well-designed, especially compared to the old-fashioned metal petcocks.
To Changing Coolant
