'Loose' steering at 75 mph plus
Old Nov 3, 2016 | 10:09 PM
Road Runner's Avatar
Road Runner
St. Jude Contributor '03 & '04
Default 'Loose' steering at 75 mph plus
I need a little help diagnosing the issue. 2001 M6 coupe with 200,000 miles. Stock suspension, shocks replaced at 100,000 and still performing. Tires replaced and balance performed around 15,000 ago.
Recently I've notice at 75 mph I have a little play in the steering. At 70 mph no play. It's as if the front end is lifting allowing the front end to move.
Are there parts that wear that would cause this to happen that I now have to replace? What should I be looking for?
Old Nov 3, 2016 | 10:30 PM
StingrayRebel's Avatar
StingrayRebel
do you remember what your alignment specs were set to when it was last done and how long has it been?... check the steering linkage bolt that holds it to the rack as well as the rack bolts that hold it to the cradle... make sure there isn't any excessive play in the linkage or and watch the rack while someone turns the wheels and make sure the tie rods or the rack itself isn't moving, there is a bushing on one of the rack bolts that can wear out and make the steering feel sloppy... that's where I would start
Old Nov 3, 2016 | 11:10 PM
Road Runner
Originally Posted by 8VETTE7
Might also be the cars magna steer is failing. That feature increases steering effort at higher speeds to avoid the light steering at higher speeds. If it is magna steer then there should be a code set. IIRC it is C1241.
Thanks, I will check
Old Nov 4, 2016 | 11:12 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You should NEVER have any free play in the wheel. At ZERO mph or 187mph!
Try this. Have someone (a helper) start the engine and rotate the steering wheel "SLIGHTLY" left & right. Enough to move the front wheel ever so slightly left and right.
While they do that, you Inspect each and every movable joint in the front suspension for ANY lost motion.
Pay particular attention to:
- Tie rod ends at the steering rack
- Steering shaft connector where the steering shaft connects to the steering rack input shaft
- On the passengers side of the steering rack is a rubber isolation bushing that the rack mounts to. Make sure that it is not damaged/missing/loose
- Upper and lower A arm bushings. Make sure that there isn't any SLOP when the wheels are being moved (left & right)
The wheel HUB bearings could also be bad but you would need to jack each wheel off the ground and do the 12:00 / 06:00 PUSH PULL TEST to see if the hub has any bearing slop.
Please let us know what you find.
Bill
Old Nov 4, 2016 | 11:58 AM
Road Runner
Old Nov 5, 2016 | 09:30 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
OP says car has 200,000 miles on it.............I'd be thinking that ALL the front end parts (ball joints, tie rod ends, a-arm bushings) have reached the end of their life cycle, and should be replaced.
Old Oct 17, 2017 | 05:15 PM
Road Runner
As it turns out both front end outer tie rod ends were warn and created the issues that I was experiencing. Easy fix, problem gone.
Old Oct 20, 2017 | 02:47 PM
T5Mika's Avatar
T5Mika
As an aside, I have had three racks in my car, and all of them have had some play. The rack preload can be adjusted, and it helps for a while but will wear the rack down even faster eventually.
You can't get a new rack anymore and the rebuilt ones are pretty much garbage. The rack and pinion are not machined, they just replace the seals and spray some black paint on.
To 'Loose' steering at 75 mph plus
