Slight Rumbling at Idle Normal?
how many miles ?
if you had a cam you would hear it for sure!
you may need to give the maf a good cleaning and install fresh plug's and wire's give her a slight tune up would deft not hurt
Yes the engine canand does move a bit on the type of engine mounts that the C5 has. THAT IS NORMAL AND THAT IS ANOTHER REASON THAT YOU SHOULDNT feel any engine harshness in the interior. The engine mounts soak up those issues. If you have a significant engine misfire, there are a couple of ways you can see it:
1- IF, you check the DTCs while the engine is running, you will see a P-0300 DTC
2- The Check Engine Light (CEL) will FLASH during PCM detected misfire if the P-0300 DTC is set.
HOWEVER,, the engine can run rough for several different reason and not set a DTC.
1- Dirty MAF
2- Un-metered air leak (Air leak in the ducting between the MAF and the Throttle Body or from a damaged / deteriorated / loose vacuum line/fitting
3- Loose Spark plug wire
4- Bad Spark plug wire
5- Dirty throttle blade & Throttle body throat.
6- Nasty air filter
7- Fouled plugs (NOTE) GM AC Delco Plugs are designed to last and run normaly for at least 100,000 miles (as per the GM guidance) Most change them around 50K-70K.
8 Damaged/ bad/ or defective coil
9Damaged/ bad/ or defective fuel injector
Your car sat for a LONG TIME. I strongly recommend that you run a couple of tanks of fuel with a treatment of CHEVRON TECHRON Fuel System cleaner!
Bill
PS
As I was logging on to CF, I was thinking, Man, I wonder how Cindy is making out with her car??
Been off the forum for a while and not keeping up with events.
That being said, some people are a lot more sensitive to vibrations than others. Who knows what was done to the car previously. It was also in an accident.
Ive troubleshot a LOT of C5s and had crazy vibration issues cause by dozens of weird issues:
Broken exhaust mounts
Bad engine & differential mounts
Exhaust systems touching body parts
Poorly installed headers
So,, Just saying...
1- Dirty MAF
6- Nasty air filter
Bill
PS
Been off the forum for a while and not keeping up with events.Hey Bill!
I sent you a pm quite a while ago about the AC but never got a reply. I figured you must be busy since I haven't seen you on here much lately. I haven't been really either so who am I to say!
I will certainly do what you suggest just to rule out those possibilities. There are no codes currently coming up. I did send you all the codes that were showing then. Maybe it's in there?
Just wish I really knew if it was normal or not since we have a few differences of opinions. Now that we just put on my after market exhausts and they sound sooooo good, the loping just goes with the whole sound and feel! But, do want to check things over just to make sure.
Thanks for the advice Bill!!!
P.S. The vette needs a new front bumper as Extreme Dimensions sent the wrong one that wasn't updated for fitment....especially the turn signals which don't fit whatsoever! They are sending me a new one, but I'll have to get it painted and all, plus the hood needs to be redone also....can see the sanding marks he left and bits of junk in it. Also have a humming going on but think it might be the wheel bearings. If not, the tires. Always something it seems!
Completely agree. Some people also hear certain frequencies of sound more-so than others.
