Quicktime Blowproof Bellhousing removal
Old Nov 5, 2016 | 09:43 AM
Bossdog's Avatar
Bossdog
Default Quicktime Blowproof Bellhousing removal
I have my 2001 Z06 in the shop to get a new LS7 clutch and torque tube rebuild. Neither I nor the shop new there was a Quicktime Blowproof bell housing already installed. After disassembling the underside, they realized they would have to take a different approach; from the top side. So they loosened the engine, tilted it enough to slide the bell housing off.
Now he wants an additional 11 hours labor. I don't know if that is fair or robbery. I appreciate input from someone knowledgeable in this area.
thanks
Old Nov 6, 2016 | 12:30 PM
Bossdog's Avatar
Bossdog
Anyone ?
Old Nov 6, 2016 | 12:46 PM
Chris Stewart's Avatar
Chris Stewart
It does make more work for a clutch job, since it's one solid piece and the bottom doesn't come off like a stock bell. Maybe consider leaving the top bolts out, so it's easier to remove next time? An EXTRA 11 hrs seems like alot, but what can you do.
To Quicktime Blowproof Bellhousing removal
