Service active handling
Old Nov 6, 2016 | 08:45 AM
apache88's Avatar
apache88
Cruising
Default Service active handling
I understand this topic probably has been discussed a million times but I have a question about this code. AS I understand it, the active handling control system on the C5 z06 is tied into the steering and braking system. When the system detects an issue it applies the brakes. My car is flashing the service active handling code and at times i can feel the car shudder slightly which I assume is the system applying the brakes. Rather than spend a ton of money repairing this problem, can the car's ECM be reprogrammed to bypass this system permanently. If the car is driven sensibly, why is this system needed in the first place.
Old Nov 6, 2016 | 01:18 PM
don37's Avatar
don37
Veteran: Canadian Forces
There are numerous safety issues at stake.
en.m.wikipedia.org/wiki/Electronic_stability_control
https://m.youtube.com/watch?v=I86mQZJWabU
