Traction sys active
Old Nov 6, 2016 | 01:16 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Default Traction sys active
under hard acceleration....ideas?? bad wheel speed sensor?
Old Nov 6, 2016 | 11:21 AM
pewter99's Avatar
pewter99
Originally Posted by 8VETTE7
Probably not BAD wheel speed sensors but more likely problems with either the wiring to/from the sensors or the connectors themselves having wither spread contact surfaces or possibly corrosion. The sensors themselves are pretty bullet proof and seldom fail.
Pull the codes and they should reveal which of the 4 sensors is complaining.....
Then get the car in the air and check the wiring for the problem wheels as well as separating the 2 halves of the connector to examine for mal-formed pins and/or corrosion. Repair as needed.
the reason I am wondering is because a couple years ago it was intermittent then went away...codes at that time indicated bad speed sensor....this new issue just started yesterday....going along about 50 and hit the gas and the traction system active lit up.....no wheel spin so that was odd....hit it again and held the throttle down and the message lit up again and you could feel it pull the power just like you would if the wheels were spinning for as long as I was trying to accelerate...I just said fk it and turned TC off
Old Nov 6, 2016 | 01:11 PM
pewter99's Avatar
pewter99
That works also except you have to turn TC OFF every time you start the car.
I strongly suspect wiring and/or the contact surfaces in the connectors and NOT the wheel speed sensors themselves.
yeah I removed them and cleaned them last time and that may have helped....
however, current codes say SWPS
Old Nov 7, 2016 | 08:47 AM
pewter99's Avatar
pewter99
SWPS is not a clean it and go repair. If it continues to create a problem then replacement is the ONLY option. Is this on your 99???? If so then there are NO new replacements available. ONLY thing available will be previously owned.
If the car is a 2001 - 2004 then there are still new SWPS available......
oh I know...
Old Nov 8, 2016 | 02:09 PM
pewter99's Avatar
pewter99
disconnected battery for awhile...reconnected....so far...so good
Old Nov 8, 2016 | 02:26 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
IF,,,,,,,,, you have that TRACTION SYSTEM ACTIVE DIC Message and NO EBTCM DTCs, the EBTCM computer "THINKS" that you have wheel slippage (one or both) rear wheels.
What happens if you put it in COMP MODE "if you have comp mode"???
If you have COMP MODE, that should take traction control out of the equation.
Are your differential limited slip clutches properly functioning and locking both rear axles to provide you equal limited slip traction?
BC
Old Nov 9, 2016 | 05:54 PM
pewter99's Avatar
pewter99
BC
Bill,
the codes this go round said SWPS....no wheel codes.
No Comp mode.....if I turn off TCS I don't have issues
also should be noted that with all the tuning I have had done I think my settings are far from stock
To Traction sys active
