LS-7 part throttle tune now wonky...something mechanical??
Ok, so after fighting idling/part throttle issues with my LS-7, I found a tuner that pretty much figured it out. The car was running great. With as much power as I'm making, if I'm cruising in 6th @ 65 mph, the vette just steady takes off. Now all of a sudden, it just sort of goes flat when I press the throttle in the same condition. It goes flat, then picks up for a second, goes flat then takes off. The exhaust note has changed and it almost "moans".
No codes other than MAF but it's on an SD tune. I checked all plugs and wires and all is well.
Some conditions that seem to be different:
Increased exhaust smell in cabin under acceleration
Lazy throttle response in general
Could an exhaust leak ahead of the O2's cause this condition? Unfortunately I have no way of data logging the condition.
is the weather much cooler than what it was when the car was originally tuned?... you might just need to have it touched up a bit to compensate, in my experience it's best to get tuned in cooler weather
The weather is almost exactly the same so I don't think that's it. It has to be something mechanical that changed so I'm going to get her up on jack stands and see if I can see something. I did notice that I felt exhaust on my feet under the passenger door. You'd figure I'd hear something out of the ordinary if it was an exhaust leak.
