Manual A/c controls
Old Nov 7, 2016 | 12:16 PM
Learjet31's Avatar
Learjet31
3rd Gear
Default Manual A/c controls
Greetings, I have a 98 with the manual A/C controls (see pic). My heat is stuck on and I need to replace the blend door actuator. I have searched and only found the location of the actuators on the dual climate control which I don't have. Can any of you guys help with the location?
Ken
Old Nov 10, 2016 | 01:26 PM
ersatz928's Avatar
ersatz928
The actuator should be in the same, or similar place on the HVAC box. I can check the factory service manual tonight. And I thought I was the only C5 with manual HVAC controls....
Old Nov 10, 2016 | 01:37 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You only have ONE actuator. I don't recall which side its on but, remove the drivers side under dash close out panel and use a good light and see if you can see it on that side of the air box.
PS... Its NOT monitored by the PCM/BCM so it will not throw an actuator error DTC.
Have you tried to Turn the HVAC controller ON and OFF ands/or remove reinstall the fuse that supplies the head/ actuator?
Bill
Old Nov 12, 2016 | 01:41 AM
deejbee's Avatar
deejbee
Our C5 has manual HVAC control too! And glad it does!
I bought some control panels a few months ago... they are getting harder to find and wanted some backup!
Old Nov 14, 2016 | 08:51 PM
Learjet31's Avatar
Learjet31
3rd Gear
Bill
Thank you sir. I will try that! I have tried everything besides pulling fuses.
Old Nov 23, 2016 | 11:51 AM
ersatz928's Avatar
ersatz928
For manual HVAC, the blend-door actuator is on the drivers side. Remove the trim panel above the pedals. Remove the Bose module to the right/above the accelerator pedal mechanism. The Blend door actuator should now be accessable.
Old Nov 23, 2016 | 12:20 PM
Learjet31's Avatar
Learjet31
3rd Gear
Thank you!!!!!!
To Manual A/c controls
