What header bolts for LS6
Old Nov 10, 2016 | 05:03 PM
jallen355's Avatar
jallen355
Default What header bolts for LS6
About to install a set of LG long tubes on my 02 ZO6 and searching for a decent set of header bolts. I see two different lengths (0.984 & 1.185) and a multitude of options from the Fleabay stuff to Stage 8 Locking Bolts (which look to be a pain in the **** to deal with the "C" clips and, of course, the ARP's. Anyone with experience make a good suggestion for me please?
Old Nov 10, 2016 | 05:05 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
Any reason you don't want to use the OEM ones?
Old Nov 10, 2016 | 06:00 PM
Cheesecake 07's Avatar
Cheesecake 07
I did the ARP studs. I like em...easier to line up your gaskets and look cleaner.
Old Nov 10, 2016 | 06:29 PM
Fastbird's Avatar
Fastbird
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
Second for the ARP Studs.
Old Nov 10, 2016 | 11:07 PM
grantv's Avatar
grantv
What I did, they work fine. I'm not a fan of studs as they can make a tight install more so.
Old Nov 10, 2016 | 11:16 PM
StingrayRebel's Avatar
StingrayRebel
stock work just fine or polished stainless if you want something that looks nice... I'm personally not a fan of studs, for me they just get in the way
Old Nov 11, 2016 | 06:37 AM
Cutlassmaster's Avatar
Cutlassmaster
I used stock but they bottomed out so i went studs. Ebay had stainless with the nuts for about thirty something $ and they worked perfectly. Nuts have the serrated bottom so they dont losen up. Had them on for over a year no issues. Also used a remflex gasket that ensured no leaks.
Chris
Old Nov 11, 2016 | 07:24 AM
vettenuts's Avatar
vettenuts
Third.
Old Nov 11, 2016 | 05:45 PM
jallen355's Avatar
jallen355
I "assumed" the length would become an issue with oem bolts and header flange thickness. I haven't taken the stock manifolds off, but I was thinking that the stock pieces would have thicker flanges. Am I wrong there? That's the biggest part of the "could" in my head, actually. Bolt length.... Just as already posted in this thread by others, it seems that oem bolts work in some cases and not in others with regards to length. I don't think studs are the answer for me in this particular situation. Just looking for a set of bolts that are not going to have me chasing leaks and that will actually fit properly.
Old Nov 11, 2016 | 09:21 PM
StingrayRebel
potz speed and performance used to sell some really nice polished bolts on ebay for cheap but it doesn't look like they have anything listed on ebay anymore, not sure what happened there
To What header bolts for LS6
