Broken Electronic Brake Control Module) 2000 use newer model?
hi my Electronic Brake Control Module is broken ( always flashing ABS)
for year 2000 C5.
I was wondering if Newer models are compatible with the 2000 C5?
The reason is because they don't make the EBCM part new anymore and I heard it cost $2000 $3000 to get one, and there's no guarantee it will last very long
hopefully if I got a new EBCM I could get a 2015 or 2016, (and spend $2000 or $3000?), But I don't know if it would be compatible with my old car from 2000
Reason: &
10pcm no codes
28tcs one code;c1243h
40bcm no codes
58sdm no codes
60ipc no codes
80 radio no codes
99hvac one code:b0361h
a0–ldcm seven codes: b2206h,b2282h,b2284h,u1255h,u1064h,u1016 h,u1096h
a6–scm no codes
b0–rfa five codes:u1255h,u1096h,u1064h,u1016h,c2105h
what are your thoughts?
10pcm no codes
40bcm no codes
58sdm no codes
60ipc no codes
80 radio no codes
a6–scm no codes
CLEAR all those codes and then report the ones that return
The C1243 indicates a stuck/sluggish Brake Pressure Modulator Valve (motor/Pump) Some people do not use the antilock braking system frequently enough and that causes the motor /pump to not operate freely or at all.
You can try to apply a separate 12 VDC power supply directly to the BPMV motor leads inside the module and run the motor manually short burst to free it up. Some people have ben successful with this procedure. Before you do this, I would make sure that you have new fresh brake fluid in the system for best results.
If that's all the EBTCM DTCs that you have, nothing is wrong with the EBTCM.
BC
awesome!
I cleared all the codes and guess what only one of them came back.
28 – TCS C1243H
by the way, indicators that turn on are
service active handling
service traction system
service ABS
I also took the car for a drive around the lot tried pressing the brakes hard etc. to see if any more error codes would show up, and no more error codes showed up. just 28–TCS C1243H
Reason: more details
The two relays are replaceable BUT,,, They are NOT your issue. One relay is the internal power relay and the other is the MAGASTEER power relay.
You need a new BPMV OR Try to get the one you have to free up the motor/pump!
Plain and simple.
You should make sure that all of your POWER and GROUND feeds for the module are 100% DIT DOT PERFECT. The Ground LUG on the motor is well known to get loose and corroded. Check that!
Your module will look like this( yours will be in the front)
This is how you open the module and access the Power lead to the motor to run it if you don't have a TECH 2
You can try to apply a separate 12 VDC power supply directly to the BPMV motor leads inside the module and run the motor manually short burst to free it up...
BC
How would I do this? Do I need to buy something from the store? if so what would i buy?
Any 12 VDC battery will work. If you have a battery charger that isn't a SMART CHARGER, that will work. A Jump Starter Pack will work.
Just find a spare male pin that you can insert into the 12 VDC feed to the motor plug inside the module and apply the GROUND WIRE to the GROUND LUG on the back of the motor. The motor should RUN. Let it run in short burst.
I had this problem I took my vette out got up to 40 mph and I stomped the brakes and my system started to working again with no error codes the last couple of days . Well today I got in car codes are back again dang .
Reason: To update status
LOL!! I love it Trial by fire!! I make the EBTCM System work every chance I get, Wet roads, frozen roads, sandy roads,, ect Even DRY roads... Mine has never failed
I actually just got the EBC module to work too by filling the tires up a little over normal and then peeling around a corner to destabilize the car and the anti lock brakes turned on and literally nothing is “flashing as broken” anymore it’s amazing.
Yes amazing glad I tried this and it worked . The problem had been driving me crazy
caddy 2006 did a swap from a early model to a late model ebcm, i have bought all the parts and I'm going to attempt it. check out his thread, he laid it all out.
