oil pressure switch
Old Nov 12, 2016 | 11:44 PM
namvet6869's Avatar
namvet6869
Default oil pressure switch
Is there a easy (well not easy) way to replace the oil pressure switch on a 2000 model without removing the intake etc. Just moved up from a C3 to a C5. Doesn't look like things are much easier to work on in this one either.
Old Nov 13, 2016 | 10:54 PM
jrprich's Avatar
jrprich
Based on what happened to my 99 I would suggest that you don't just replace the OPS but relocate it as well. I had three OPS fail on my 99 until I relocated it.
Lots of posts on relocation on this forum.
Jim
Old Nov 14, 2016 | 03:05 AM
SilverC54me's Avatar
SilverC54me
Do it the right way, follow the instructions for removing the intake.
Carefully clean around the intake to get accumulated derbies off it. Also I would suggest replacing the intake gaskets. At 16yrs old these will be quite flat and not seal well.
Gary
Old Nov 14, 2016 | 07:49 AM
mike48750's Avatar
mike48750
Just did mine per the FSM. About 3 hours. Cost was around $70 including intake gaskets. The torque specs for the intake are in INCH pounds not foot pounds. Slide the manifold forward about 6 inches to disconnect the 3 items on the back of the manifold and extend that pesky vacuum line for the hvac before reassembly. I enjoy working on my C5 so it was a pleasure to do it myself. If you were a little closer I'd come over and give you hand. Have fun and good luck. Mike
Old Nov 14, 2016 | 08:29 AM
Pounder's Avatar
Pounder
1/4 mile/AutoX
I added a length of hose on the small vacuum line, much easier to re-install the intake.
Old Nov 14, 2016 | 09:03 AM
Pounder's Avatar
Pounder
1/4 mile/AutoX
if your interested in re=locating !!
File Type: docx
File Type: docx
File Type: docx
Old Nov 14, 2016 | 09:30 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
IF,,,,,,,,,,,,,,,, You remove the intake I STRONGLY recommend not just sliding it back. You will be SHOCKED at how much sand, dust, dirt, acorns, ect are contained in the cracks and crevices and that stuff will NOT let the intake gaskets seal. It can also get into an intake port. Remove the manifold, clean all the crap out, replace the seals and consider it done correctly!
Bill
Old Nov 14, 2016 | 09:41 AM
namvet6869's Avatar
namvet6869
your files are all jiberish pounder
Old Nov 14, 2016 | 09:43 AM
feeder82's Avatar
feeder82
and having worked on a c3, there are a lot of repairs on a c5 that are easier to do, one of them is removing the intake
Old Nov 14, 2016 | 01:45 PM
runner140*'s Avatar
runner140*
Jiberish you say...ha ha
Old Nov 14, 2016 | 01:56 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
Originally Posted by 8VETTE7
You need a reader for .DOCX files. It would have been nice if pounder had saved the files as PDF when he created then in Microsoft Word. (that is an option when saving MS Word files). That way anyone could open them with a free reader rather than with a pay for it MS reader.
Hint pounder.......
Open Office is free, gee you want me to do the work too
Old Nov 14, 2016 | 02:28 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
the things I do to keep you guys happy. LOL
File Type: pdf
File Type: pdf
File Type: pdf
Old Nov 14, 2016 | 02:45 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
Nope..... I'll do it for you. PDF is a universal file type while .DOCX is a proprietary file type that far fewer can open.
Attachment 48036420
Attachment 48036421
Attachment 48036422
Ha Ha beat you to it !! I have just always used Word to file my doc's , I guess I figured everyone uses Microsoft Office, my bad
Old Nov 15, 2016 | 09:16 AM
El original's Avatar
El original
Try this first and let us know if it can be done. This guy does it with one hand and the other holding the cam,(or a beer) lol. Rob
To oil pressure switch
