TPS sensor connector help!
Old Nov 13, 2016 | 01:36 PM
eleonb's Avatar
eleonb
Default TPS sensor connector help!
I have 2004 with a corroded tps pin, female side,. Does anybody know how to release this pin from connector, looks like it should come out through the front. Any help would be appreciated.
Old Nov 13, 2016 | 02:40 PM
Carl Timonen's Avatar
Carl Timonen
The pins come out from the wire side of the plug. When I've removed pins, I use a pin removal tool that inserts from the open end of the plug and releases the pin's locking tab. Some plugs may have a lock that holds the wires and pins in, usually seen as a different color then the rest of the plug. I'm just not familiar with the one you're working on.
