I have an issue and have seen others on here that had the same problem.
There is a loose baffle inside that rattles around and I was wondering if anyone has cut one open to reweld the baffle and then weld a cover back over your whole. Do it on the topside so when it's re-installed it wouldn't be visable.
It would be nice to just buy new ones but being on disablility that is too expensive for me. Seems you could fix them instead.
Reason: spelling
Tough question... Who would be doing all the work? If a shop is doing it, it may be less expensive to just get a new one.
Maybe try denting the area around the loose baffle with a small ball peen hammer enough to tighten the loose baffle.
If you knew exactly where the loose baffle was, you could drill a small hole into the case and into the baffle lip and SPOT WELD it back to the case. (fill the hole with weld.)
How do you know it's a loose baffle? No chance something foreign got in there (piece of cat, misc items from mufflers install...)? If it is a loose baffle, as BC said, how do you figure on finding out where it's loose without fully opening it up (and very possibly ruining the integrity)?
If you do know where it's loose, then sure, either drill thru and blind rivet or plug weld it.
I don't own a cat....
I can tell which half of the muffler it seems to be, I would be doing all the work & welding so it would cost next to nothing.
I figured I could cut a 4"x6" rectangle on the topside near where I thought the loose piece was and fix it and weld a piece of steel back over
the opening.
I could be something in there but I hoped that after it was cut off (they are welded on) I may be able to shake it out.
How would I ruin the integrity by cutting a hole in it as long as it was sealed back up good? I try to think things through before starting a project, sometimes I don't think of something I should.
I have 4, I know of all pieces missing (eye, tail, leg depending on what cat), so it's nothing from one of mine.
You sound like you have a good head on your shoulders (where else would it be...). As long as you seal it back the same as the factory did, you should be OK.
What do you plan to use to cut the hole? Zip discs, tin snips?
Assuming the shell is stainless?
You're going to do a full weld around the repair piece? Careful not to ruin any fill if present, and watch for warping. Take before, during/guts, and after pics.
Worst case scenario you make it worse.
I'm not sure what brand, but someone posted pictures of a muffler they cut apart and fixed here so it can be done. So, go for it.
That picture has been posted a lot. It was an OEM GM Ti muffler.
It was cut apart and not welded back together. Sacrificed to show us how they were constructed and how well they flow. There is VERY LITTLE restriction inside to limit air flow.
Hey,, Just pull the muffler off and see if there is something in it that you can shake out.. That may all that's wrong.
Just GOOGLE C5 flow master muffler cut open and view "pictures" and see if you can find the model muffler that you have. There are LOTs of cut open pictures:
Thank you Mr. Curlee, I never even thought to search for cut a way shots of the muffler.. I appreciate the suggestion. It seems like "IF" it's not something in there rattling around the baffles will be easy to reweld.
