fr wheel ramps
Old Nov 14, 2016 | 02:52 PM
Dahc's Avatar
Dahc
Default fr wheel ramps
I was looking to make some fr wheel ramps. I have some osb sheets of wood. Could i use them layered together to make some ramps? Do you think they would support the car well?
Old Nov 14, 2016 | 05:10 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
I would not use them, use 2x10's or 12's
Old Nov 14, 2016 | 08:31 PM
grantv's Avatar
grantv
If you mean the end result would be solid wood top to bottom, sure. Even a very short span would snap like a toothpick though. It would be tremendously easier to build ramps like the previous post (I made 2 or 3 sets similar).
Old Nov 14, 2016 | 08:49 PM
I agree with what Pounder said - better to use 2x10 or 2x12 solid lumber pieces to make the ramps.
Here are some ideas for making the ramps from other forum members:
File Type: doc
File Type: doc
Old Nov 14, 2016 | 09:31 PM
Dahc's Avatar
Dahc
thks for the replies. I had the wood laying around so i thought i would put it to good use. My idea was to lay it on top of each other and screw it together. Did not know if it would be safe or not.
Old Nov 17, 2016 | 09:11 AM
huesmann's Avatar
huesmann
If that's what you're doing you should be fine--if you're laying the whole schmear on the ground (see attached pic) and as long as the layers are wide enough. If you plan to have any unsupported length, like pounder's pic has (with blocks in the middle and end), then no, don't use OSB--it has little flexural strength, even if laminated.
Old Nov 18, 2016 | 10:48 AM
grantv's Avatar
grantv
These are my winter ramps. Just high enough to make it easier to do an oil change come spring, and keep the tires off the concrete.
Then I have others that are thicker for getting vehicles a bit higher if needed.
Both are made with a slope that the front of my car makes it with just barely rubbing.
Old Nov 18, 2016 | 10:25 PM
Dahc's Avatar
Dahc
I went out and bought some rhino ramps for $30. Thanks for all the replies.
Old Nov 21, 2016 | 09:18 AM
huesmann's Avatar
huesmann
If they're anything like my Rhinos, they won't work--Vette is too low. You need Race Ramps, unless you're using some other kind of supplemental ramp to get a couple more inches up to the Rhinos.
Old Nov 21, 2016 | 02:13 PM
runner140*'s Avatar
runner140*
When I used Rhino Ramps years ago, I had to put carpet Squares under the ramps to keep them from sliding forward.
Old Nov 21, 2016 | 09:13 PM
Dahc's Avatar
Dahc
I used the rhino ramps without a problem. They did hit the bottom spoiler a little bit. They did want to slide a little bit. I will try the carpet good idea.
Old Nov 24, 2016 | 09:32 AM
GUSTO14's Avatar
GUSTO14
Race Ramps is having a number of sales right now. Including a 15% off offer thru 11/30/2016.
PM me with an email address if you want their add.
GUSTO
To fr wheel ramps
