Another cooling fan question
Old Nov 18, 2016 | 01:52 PM
mykul68's Avatar
mykul68
7th Gear
Default Another cooling fan question
First and foremost, I hope er'one has a very happy Thanksgiving. I have searched the cooling fan threads and haven't found what I am looking for so please bare with me. Can anyone tell me how or provide a diagram for manual control of both fans on high speed. Maybe something similar to the C5 fan trick on rangeraccleration.com. That jumper tip controls both fans on low. Or could I completely bypass the ECM and wire directly from a power source through a relay or relays to new pigtales plugged into the fans. Any advice would be much appreciated.
1999 Magnason supercharged FRC
Old Nov 21, 2016 | 01:10 AM
edram454's Avatar
edram454
sac city has a device called cool it. depending if your car is a v2 or v3, you install these plug in chips in your computer (very easy for anybody to install), attach a ground (all shown and explained with instructions and also on youtube) and you can turn on the high speed fans any time you want with a wireless remote. I live in miami and this is always a great thing.
Old Nov 21, 2016 | 08:27 AM
ersatz928's Avatar
ersatz928
Install a Hayden adjustable fan controller, they cost about $30. This will automatically turn your fan on when it reaches the temperature you set...why bother with a manual fan control?? I wrote an installation DIY for the Hayden, back around 2001, search thru the Tech notes/tips on this forum. With a stock thermostat, and this controller, my water temps runs between 190 and 205, and up to 215 in stop & go traffic in the summer with the AC on.
https://www.amazon.com/Hayden-Automo.../dp/B000C3BB6M
Here is a link to someone elses install :
http://www.z06vette.com/forums/f5/46...nvolved-18529/
Old Nov 22, 2016 | 11:57 AM
KBL's Avatar
KBL
Default Fans
I had my tuner set my fans to 160 and 175. I also popped for a DeWitts radiator and fan set up. Expensive but worth every penny my car rarely goes over 178, uphill, stop and go, freeway she stays right there.
To Another cooling fan question
