Wide band connection
Old Nov 21, 2016 | 10:40 PM
Caveboy's Avatar
Caveboy
Active Streak: 90 Days
Default Wide band connection
Where can I tap key on supplied power for my wide band connections inside my car?
Old Nov 21, 2016 | 11:52 PM
StingrayRebel's Avatar
StingrayRebel
on my car there was a connector in the passenger footwell near the bcm that has 12v constant/12v key on/ground and I wired my wideband into the pigtail of that connector... mine is an 02 and I believe only certain years had that connector but I'm not sure which ones so you would have to check
Old Nov 22, 2016 | 12:10 AM
Caveboy's Avatar
Caveboy
Did anybody wire it into a relay?
To Wide band connection
