window regulator
Old Nov 26, 2016 | 04:33 PM
polymer1's Avatar
polymer1
Default window regulator
passenger window started making some noise when operating and then it started binding and then it stopped moving at about 2/3 closed position.
Is this a common problem?? if anyone has any tips on installation I would appreciate
I have a 2004 with only 13K miles and I hardly ever use the passenger window
Old Nov 26, 2016 | 04:47 PM
007Duc's Avatar
007Duc
The window regulator is cable operated. More then likely the housing on one of the cables broke and the cable started fraying and now is bound up. I just finished replacing my drivers side for this same problem. It's not horrible hard to do. I'd mark where everything is as I took it apart. As that should get you close but you will probably still need to make adjustments.
