Crazy Electrical Problems...
Old Dec 8, 2016 | 02:52 PM
jade0921's Avatar
jade0921
2nd Gear
Default Crazy Electrical Problems...
I am having trouble with my 2001 Corvette. The headlights are alternating in opening and closing, turning off and on, interior lights staying on, even after the car is off (which has caused the battery to die twice now), and turn signals not working etc., which has been giong on for some time and I use the hazzard trick to manipulate them into working.
I have pulled the following codes and hoping someone can direct me to what the issue is...
BCM Codes - B0432H - Rear Defogger Relay Circuit
B2592H - Column Lock / Unlock Drive B
B2593H - Column Lock / Unlock Drive B
LDCM Codes - B2282H - Battery #1 Circuit
B2284H - Battery #2 Circuit
RDCM - B2282H - Battery #1 Circuit
B2285H - BAttery #2 Circuit
SCM - B0851 - Battery out of Range
RFA - U1000H & U1255H - Class 2 Communication Malfunction
U1064H - Lost Communication with XXX
What could be the problem? Could it be the BCM going?
Any help would be greatly appreciated.
Thanks!
Old Dec 9, 2016 | 12:25 PM
jade0921's Avatar
jade0921
2nd Gear
Great, thank you! I will try to tonight, before anything else and let you know!
