Tech 2
Old Dec 14, 2016 | 09:11 AM
Darkvette98's Avatar
Darkvette98
Default Tech 2
Hi guys, I'm debating getting a tech 2, I was wondering how many ppl on here have one...if they are worth it...and what the latest coverage is with the most up to date software...I have other Chevys I own and could use a good scanner but want to be sure of the coverage
Old Dec 14, 2016 | 10:18 AM
Pounder's Avatar
Pounder
1/4 mile/AutoX
I have had mine for a couple years, my software is good up to 2013. I bought mine mostly for the Auto bleed function, and have used it for other things also. Well worth the money !!!!!
Old Dec 14, 2016 | 11:55 AM
kp1's Avatar
kp1
Just got mine recently. It was $254 delivered. The brake bleed is a nice thing to have. The big deal is that you can access the Body Control module and make changes there. Also, the very clear drill down to what is causing a trouble code is nice.
So far I used it on a 2009 Pontiac G6 to replace a remote key entry radio reciever that requires a reprogram of the BCM, bled the brakes, programmed new key fobs, & isolated a traction control trouble code directly to a defective speed sensor on the front passenger side. Without the Tech2 I would have had to pay the dealer and it would have exceeded the cost of the Tech2 by far, so I'm money ahead right now. The rest is just gravy.
It does stop at 2013 cars as previously stated.
Old Dec 14, 2016 | 12:02 PM
f6john's Avatar
f6john
How tech savvy do you have to be to use it?
Old Dec 14, 2016 | 12:22 PM
Kelly.s's Avatar
Kelly.s
$254 is a great price. Where did you buy it?
Old Dec 14, 2016 | 12:25 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
tuff question, I was a GM tech for 25 years but before the Tech 2 came out, it walks you through most, and this forum helps also !!
Old Dec 14, 2016 | 01:15 PM
Darkvette98
Ok I have a 2011 Cruze and the 98 vette... I wanted something under 300 that would do both but I was reading and it seems the Cruze might be on the new system?? Anyone who has one can you verify that the clone would work or should I look at one of the laptop software scanners ??
Thanks again guys
Old Dec 14, 2016 | 02:11 PM
Darkvette98
Also is there another good after market scanner that works well with bidirectional features under 500
Old Dec 14, 2016 | 05:30 PM
Last C5's Avatar
Last C5
+2 What he said.
Old Dec 14, 2016 | 08:52 PM
kp1's Avatar
kp1
AliExpress. Mr. Cartool Shop. Actually, itwas $257 delivered.
Old Dec 15, 2016 | 03:21 PM
04zjimc's Avatar
04zjimc
I bought the whole kit...I could have done without the case.. works perfect! From Hong kong 5 days I think it was...
Old Dec 15, 2016 | 04:55 PM
Darkvette98
Nah the case is sweet.. keeps it all in place... I found out from a friend who works a dealership, that my Cruze is not compatible with the tech 2... has anyone looked into any other scan tools other then the tech 2...I was looking at autoengunity...anyone have any experience with pro ish grade scan tools
Old Dec 15, 2016 | 05:29 PM
K-Spaz's Avatar
K-Spaz
From: Central PA. - - My AR15 identifies as a muzzleloader
I believe in the Beer Fairy
Not very. If you can figure out how to plug in a cable that only goes one way, you can do it.
It's just a scan tool, albeit a big one.
Runs out of coverage around 2009 if I recall correctly. You'd need the newer tool for newer cars.
I've done quite a bit with mine and consider it to have been a great investment.
To Tech 2
