Cooling System Issue
Apparently I also needed to disconnect the Evaporator Core but I have no clue how to drain the A/C refrigerant from it, and when I DO disconnect it from the firewall, it starts spewing refrigerant. Scanned the service manuals to no avail. Does anyone have a clue how to drain refrigerant in the '98 Corvette?
I'd appreciate any pictures, information, or tips you learned while working on your HVAC module. (I'm 17 and doing it all alone, so any help is really appreciated.)
Look around on YouTube - it is sort of my go-to.
Also, there may be some hard to find screw or clip or bolt, etc. that has to be freed to get the core out. It seems to happen to me all the time that there is one MORE fastener that I missed.
Good luck with your project
In any event, good luck as you move up the Corvette learning curve.
Your SUPPOSE to recover the R-134. If you just vent it, you have to do it very slowly from the gas side of the system. If you do it wrong, you will vent the refrigerant oil out of the system along with the R-134.
NOTE. If you vent and open the AC System, you should replace the orifice restrictor tube, the receiver dryer and add the correct amount of oil for your compressor into the new receiver dryer. Then you need to vacuum put the system and add the exact amount of R-134 that it needs.
