Ported Z06 Vs LS1 heads...?
Old Sep 19, 2002 | 07:42 PM
MiamiDave's Avatar
MiamiDave
Default Ported Z06 Vs LS1 heads...?
On a street driven daily driver, with same cam, intake, and exhaust systems-what would be the HP/trq difference between similarly ported Z06 vs ported LS1 heads...?
Old Sep 19, 2002 | 08:34 PM
Ram Air Tony's Avatar
Ram Air Tony
Default Re: Ported Z06 Vs LS1 heads...? (MiamiDave)
roughly 10 rwhp or less :yesnod:
hope that helps
Old Sep 20, 2002 | 01:32 AM
pkmoose's Avatar
pkmoose
Cruise-In III Veteran
Default Re: Ported Z06 Vs LS1 heads...? (Ram Air Tony)
hope that helps
:yesnod: and the Z06 heads will cost alot more :smash:
Old Sep 20, 2002 | 01:37 AM
Sales@MVPAutoParts.com's Avatar
0Sales@MVPAutoParts.com
Former Vendor
I would say go with the 6.0L truck heads instead. In my opinion, it is a much better bang for the buck. :cheers:
Old Sep 20, 2002 | 06:45 AM
MiamiDave's Avatar
MiamiDave
Default Re: Ported Z06 Vs LS1 heads...? (Tuan Le)
DAYUM! On some H/C packages they claim the '06 heads make 30-40 more HP! Maybe they port it differently, or they have to include those hot numbers for some sales reason :eek:
Old Sep 20, 2002 | 07:39 AM
CJS's Avatar
CJS
You could also use the Z06 heads as is, unported. Then there is a difference between them and the stock Ls1 heads. If you can get a used set of heads this is fairly cost effective to.
Old Sep 20, 2002 | 09:09 AM
MattG's Avatar
MattG
Cruise-In I, II, III, IV & V Veteran
CI-I & II Auto-X Champ
Default Re: Ported Z06 Vs LS1 heads...? (CJS)
LS6 castings' advantages over LS1 castings really shine when you are using a cam with higher lift (~.580+). I believe if you are using a cam that size, you will see 15-20rwhp differences at least and maybe even more as the lift gets higher and displacement increases on the motor.. For a mild or mid size cam daily driver, heads/cam car I think LS1 castings are the best way to go. LS6 castings alone are $1400, so you have to make sure the extra power you are going to get is worth that much money to you..
As for the 6.0L castings, they supposedly have very similar ports to LS6 heads but the chambers are larger, thus lowering the compression ratio. I don't really think 6.0L castings are great for a heads/cam application because there really is no way to regain the compression ratio that you lose from going to them. If you are building a complete motor, then 6.0L heads may be a better choice because you can make up for the lower compression with pistons that have a higher compression height.
[Modified by MattG, 8:11 AM 9/20/2002]
Old Sep 20, 2002 | 10:23 AM
LG Motorsports's Avatar
LG Motorsports
Premium Supporting Vendor
St. Jude Vendor Donor '03-'04-'05-'06-'07-'08-'09-'10-'11
Our LG Motorsports G5 heads flow the following:
@ 28"
LS1 307cfm @ .550
LS6 314cfm @ .550
LS6 Big Block heads 335cfm @ .600
There is about 10rwhp difference between the two. The choice is between a 500 flywheel hp packge and a 510flywheel hp package. That is $110/hp for the last 10hp.
The big block heads have great flow, huge hp numbers at the top end but no low end torque on a small block. The cubes of the 427 make all of the lost torque.
Then again you can go with the 427ci, and that extra 100hp will still cost the extra $110+ per hp, but life is no dress rehearsal.
Thanks,
Lou Gigliotti LG Motorsports
To Ported Z06 Vs LS1 heads...?
