Harmonic balancer advice?
Anyone had any thoughts to shed on this before I pull the belts off again? Thanks in advance.
2. Belt dressing on our belts can and will make thing worse.
3. Wash the belt dressing off with something like simple green degreaser.
4. Obtain a small toothbrush stainless wire brush and clean all the belt groves on all the grooved pulleys. Use some 240 grit wet and dry paper and rough up/clean the smooth pulley surfaces.
If you have NOT changed the AC Belt, I highly recommend that you do so.
Obtain a mechanics stethoscope or a LONG screwdriver and put it on each of the tensioners and see if one is emitting the noise.
Run the engine with out any belts and then with just the AC belt and see what happens.
Maybe I'm not looking at it from the correct angle but it appears the belt is not running on the balancer properly. It looks like the belt is half way off the pulley. Has the pulley walked out towards the front? Mine went all the way back and damaged the timing cover and oil pan. It's worth checking. Good luck.
If it is the A/C then you don't have to replace the whole unit, just the clutch.
What they are referring to is important. The Dampener has THREE separate parts. The HUB that attaches to the crank, an outer metal ring that the belt rides on and an elastomeric rubber strip that BONDS the hub to the outer ring.
That elastomeric rubber strip can become un-bonded and the outer ring can come loose and move forward (grinds against the steering rack) OR move reward and grinds into the front cover.
If your bely isn't running centered on the outer ring, it could be a very bad sign that your outer ring is separated and YES, that can make noise also.
Bill
BC
If you do it wrong you will destroy the trans. I highly recommend doing it 100% by the factory manual procedure!
Bill
1-Add enough DEXRON III automatic transmission fluid to
bring the fluid level to the bottom of the threaded plug hole.
2- Start the engine and allow the engine to idle until the
transmission fluid temperature has reached the value
specified. 30- 50°C (86-122°F) Use Trans Temp reading on DIC
3- Depress the brake pedal and move the shift lever through the
gear ranges, pausing a few seconds in each range. Return the
shift lever to the PARK range.
The vehicle must be level with
the engine running and the shift lever in the PARK range.
4- If needed, add DEXRON III automatic transmission fluid in
increments of 0.5 L until the fluid drains from the threaded plug hole.
5- Allow fluid to finish draining out of the plug hole. Install the
plug and tighten to specified value. 30 N.m (22 lb ft)
Bill
Edit: Is this write up for auto or manual transmissions?
pretty much this is the way I was going to do it. http://www.toquez06.com/tranny.html
The procedure I posted is for an Auto Trans. You didn't state if you had a Manual or Auto.
The Manual is pretty much straight forward as you stated. The Auto drain / refill is involved as I posted.
RECOMMENDED FLUIDS
Manufacturer recommends Dexron-III(R) ATF.
TRANSMISSION FLUID CAPACITIES:
Corvette - 4.1 Qts. (3.9) (L)
(1) Fluid capacities listed are approximate. Always use procedure specified under CHECKING FLUID LEVELS when filling transmission
DRAINING & FILLING
1. Raise and suitably support the vehicle. Ensure vehicle is level. Clean away all dirt and debris from the
transmission fluid drain plug area.
2. Remove the drain plug. See Fig. 2 . Allow the transmission to drain. Install the transmission fluid drain
plug. Tighten the transmission fluid drain plug to specification. See TORQUE SPECIFICATIONS .
Application - Corvette 4.1 Qts (3.9) )L)
LEVELS when filling transmission.
3. Remove transmission fill plug. See CHECKING FLUID LEVELS . Fill transmission with appropriate
fluid to proper level.
4. Install the transmission fill plug (or TFT sensor) to the transmission. Tighten to specification. See
TORQUE SPECIFICATIONS . Connect TFT sensor harness connector, if necessary. Lower the vehicle.
TORQUE SPECIFICATIONS:
Drain & Fill Plugs 20 Ft. Lbs. (27)(N.m)
