How difficult is shocks and sway bar install?
Old Dec 30, 2016 | 12:20 PM
harryk387's Avatar
harryk387
Default How difficult is shocks and sway bar install?
Bought the Johnny O'Connell Stage 1 setup and want to hear how difficult it would be to install. Is there anyway to really mess up the install?
My uncle has a tire shop that also does suspensions, is there anything special about replacing the shocks and sway bars on our cars? Or would they be able to handle it pretty easily without any problems?
Old Dec 30, 2016 | 01:00 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If I had to rate it on a scale of 0-10 and 10 being extremely complicated and need special tools and skills, it would be a 3.
A three (3) only because you need to look up the bolt torque values and get and use a torque wrench to properly torque the fasteners.
Its not difficult at all. It will consume a good part of a Saturday afternoon time wise.
Compress the shocks and use a piece of coat hanger to keep them compressed. Once there in place, cut the wire and they will expand into place.
Bill
Old Dec 30, 2016 | 04:41 PM
feeder82's Avatar
feeder82
easy hand tool replacement
Old Dec 31, 2016 | 01:39 PM
mike venth's Avatar
mike venth
mike v
Veteran: Marine Corps
Bill
The coat hanger is the best tool for the new replacements/new shocks.
Sway bars-un-bolt and put in new ones.piece of cake.. You'r going to love the new handling. Bill helped me, made it a snap. Thanks Bill
Also cleaned and painted everything.
OLD (L) End links were junk. NEW (R)
Old Dec 31, 2016 | 06:49 PM
lar66BB's Avatar
lar66BB
Those look like Z06 shocks or similar. They can be a pita to compress when new.
You will need a big pry bar.
Old Dec 31, 2016 | 08:14 PM
twostepdon's Avatar
twostepdon
You might be interested in:
http://www.pcfred.com/Vettetip/C5%20Shock%20Install.htm
Old Dec 31, 2016 | 08:28 PM
SilverC54me's Avatar
SilverC54me
Shocks and sway bars are easy items to replace. Probably a 2hr or so job on jack-stands in your driveway, or about an hour with the help of a lift.
Gary
Old Jan 1, 2017 | 11:33 AM
mike venth's Avatar
mike venth
mike v
They are Z06 with Z51 Bars and metal end links. Came as a kit from
http://www.cultragfactoryparts.com/
I put one end on the floor and pushed down hard..Took a couple tries.
But the coat hanger method worked the best for me.
Old Jan 1, 2017 | 12:06 PM
burneyr's Avatar
burneyr
I think you'll find replacing bars and shocks to be an easy job. I just did a round of maintenance on my C5 with a buddy, and we did the following in eight hours on my lift.
Replaced all four shocks
Replaced driver side differential seal
Adjusted parking brake shoes
Replaced rear sway bar end links
Replaced brake fluid
Installed a Corsa cat back exhaust
With the shocks the hardest part was getting the old ones off the car. Used the zip tie trick to compress the new ones, and it was uneventful and easy installing them. The only thing that was surprising was the parking brake shoe adjustment. I had a brake drum resetting gauge which made the job less trial and error, but it took more time than I would have imagined to get them perfect.
Outside of that, C5's are very straightforward to work on. As others have mentioned just pay attention to the torque specs and have at it. I think you will find bars and shocks are very easy to replace.
Old Jan 3, 2017 | 07:51 AM
Frame77's Avatar
Frame77
Just unbolt the four upper control arm bolts and slide the shocks in if you're not able to compress them.
The whole install takes about half an our per shock.
Old Jan 3, 2017 | 12:44 PM
SaberD's Avatar
SaberD
The most difficult part will be the front upper shock nuts if they are seized. I'd start spraying some pb blaster on them before you even order the parts.
Old Jan 3, 2017 | 03:15 PM
Quickshift_C5's Avatar
Quickshift_C5
Like the others said, very easy. I didn't even bother with the zip tie method when installing 3 of them. I did the first one with the zip ties and thought the new DRM Bilstein shocks compressed easy enough by hand. So, the next 3 I simply put one end in place and shoved it hard enough by hand to slowly compress it. Once they were compressed, I quickly moved the other end into position until it seated. It was cake and very fast.
Either way, you should be able to do it.
Old Jan 7, 2017 | 12:15 PM
momo20's Avatar
momo20
its not hard to get the shocks in place i ended up using a ratchet strap to compress the shock and then put in place...then slowly release the shock to bolt it in..worked perfectly
Old Jan 8, 2017 | 06:32 AM
buckeye1872's Avatar
buckeye1872
Originally Posted by twostepdon
I followed these instructions when I did my shock replacement. Used big azz zip ties I got from Harbor Freight. Wasn't bad job at all, doing in driveway on stands. I did the sway bar and links on a lift, with help of friend, when I put my cat back on. Again, pretty easy.
To How difficult is shocks and sway bar install?
