advise on hand porting heads.
Old Sep 20, 2002 | 04:07 PM
belair55's Avatar
belair55
Default advise on hand porting heads.
I have some experience with porting gen 1 small block heads. Will typical chamber & bowl work (short-side radius, guide boss re-shaping, etc.) work well on the ls1 heads? I am not planning on doing any reshaping on the intake and ehaust runners, just a cleanup. I am also changing to 2.08/1.60 valves and larger diam. springs. Will the gain be worth the effort? I have access to a flow bench locally. Will I need to test for flow/swirl to get the PCM reprogrammed? Any input will be appreciated :)
