E/M are reset all days (boring)
Jan 8, 2017 | 10:48 AM
Hello,
i have a problem with the information on dashboard
when i drive my corvette, i read it in km/h
if i park the car for 1 day or more, when i go back in, the dashboard is in miles/h
it does'nt make it before, and i would like to know why ?
is there a memory relay in the dashbord ? where it is ? there is an other relay ? maybe a battery like a personnal computer for the rom ?
thank you
Jan 8, 2017 | 11:23 AM
ok, i will try it and tell you what happen
(i'm in France actually ^^)
Jan 8, 2017 | 11:25 AM
and if it's not the vehicle mileage ? if it's always the oil temperature ?
Jan 8, 2017 | 11:26 AM
and thank you for you quick answer ^^
Jan 8, 2017 | 08:01 PM
I would be looking into the condition of your battery as a first step.
Jan 9, 2017 | 07:45 PM
What 8VETTE7 said...I have a Canadian spec car...When I first got the car it was constantly defaulting to KM/H when i had it set to MPH...I thought that it was because it was a Canadian spec car and that I would just have to live with it..Then I began noticing other little quirks associated with a weak battery. I replaced the battery and life was good.............
Jan 9, 2017 | 08:29 PM
Battery.
Jan 10, 2017 | 07:23 AM
I have seen the same problem before. Once it was a weak battery and the other time it was a bad battery cable ground.
Jan 10, 2017 | 02:14 PM
hello !
i have tried this : start engine, put in km/h , ride
stop the car, park and before turning off, put the "oil temp"
i go for 2h, came back and the km/h is still the same so ... it's good
but for me it's bad because is i do the same operation 1 week later, it goes, like you said, the mileage appears again in miles and not in km/h :'(
what do you think about that ? allways the battery ? (the battery is new from november :/)
Jan 10, 2017 | 02:15 PM
i will try to check all the 6 points of ground cables too ... to eliminate this
Jan 10, 2017 | 02:21 PM
thank you, i will try this too and report the effect (need to wait 1 week to know lol)
Jan 22, 2017 | 02:36 PM
i think it's a bad connection with battery
i am testing something ^^
Mar 28, 2017 | 06:37 PM
get some news :
the weather is better, never less than 5°C .... 2 week without corvette and still same km ... ok so it's a fu**g batery ...
grrr i've buy this one in a hurry ... it's my fault, never order an other battery than optima red ....
thanks for all !
