Halfshaft stuck in differential!
Old Jan 9, 2017 | 04:11 PM
jv8's Avatar
jv8
Cruising
Default Halfshaft stuck in differential!
I replaced the left halfshaft in my C5Z... the stock unit came out fine and I replaced it with this aftermarket unit: GSP NCV10999
I didn't like the way the big floppy aftermarket CV boot touches the shock mount. I decided to pull it and use a genuine GM halfshaft.
However, I cannot get the aftermarket unit out of the diff! I bought a 10lb slide hammer plus the attachment that fits behind the inner CV and slammed away with no effect.
I then bought the "axle popper" wedge fork that you drive between the diff and inner CV... no go!
Any other options?
The aftermarket splines felt a little tight going into the diff... but I didn't expect this kind of trouble getting it out.
Old Jan 9, 2017 | 04:16 PM
cbell3186's Avatar
cbell3186
Light tension on axle (from someone helping you.) Pickle fork between diff and axle. Then tap the pickle fork lightly with hammer, until the axle moves past the axle retainer clip on the splines. Watch PF angle because you don't want to score the seal on the diff.
Old Jan 10, 2017 | 11:47 AM
CamminC5's Avatar
CamminC5
St. Jude Donor '15-'16-'17-'18
The relief for the cir-clip could be slightly larger on the aftermarket piece. Get a buddy and try the pickle fork and slide hammer at the same time.
There is a chance the cir-clip, that holds the OPS inside the diff, could come loose first. In that case you will need to remove the diff from the car, disassemble, retrieve the clip, and reassemble the clip. This scenario is very time consuming, and will make you want to burn your car to the ground. Hopefully you get the axle loose.
If the worse case issues happens don't try to disassemble the diff in the car as there isn't enough room. Go ahead and pull the drive train out.
You could disassemble the aftermarket axle, drill out a relief and use a 3 arm puller to press out the axle, but this would be a last resort.
Old Jan 10, 2017 | 01:30 PM
jv8's Avatar
jv8
Cruising
Thanks for the advice!
I did get the axle out... I needed an extra hammer extension and a buddy holding the axle & slide hammer shaft in place while I used both arms and threw my full weight against the hammer!
No "light tapping" LOL
Old Jan 12, 2017 | 10:03 AM
cbell3186's Avatar
cbell3186
There's a certain amount of "light tapping" which is fueled by frustration to increase to "Come on you piece of s*** get out already!!!!!!"
Old Jan 12, 2017 | 02:50 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
LOL! I think we all talk to thing when they get stubborn and CUSS at them when they break!!!!! : :
To Halfshaft stuck in differential!
