fob reprograming
Old Jan 11, 2017 | 07:55 PM
Dahc's Avatar
Dahc
Default fob reprograming
I had my battery disconnected for a couple days and when i hooked it back up my fob would not work. So i started the relearn process. When i get to fob training you are suppose to hit reset to start fob programming but it stays on fob training. It does beep when i hit reset but will not go any further.
Old Jan 11, 2017 | 09:14 PM
Dahc's Avatar
Dahc
bo rfa no comms. I did put a new receiver in the car a couple months ago. The receiver i put in was the newer one for 01-04. I tried holding down lock and unlock with no luck. Is there a fuse for the receiver? I was thinking maybe it blew a fuse when connecting battery back up since it says no comms.
Old Jan 11, 2017 | 09:56 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
Don't you have to re-program them through the DIC ???
Old Jan 11, 2017 | 10:00 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
To match transmitters to your vehicle:
1. Turn the ignition key to ON.
2. Clear any warning messages on the Driver Information
Center (DIC) by pressing the RESET button.
3. Press the OPTIONS button on the DIC several times
until the blank page is displayed, then press and hold
the RESET button for two seconds.
4. When the message FOB TRAINING is displayed,
push the RESET button once. The message HOLD
LK + UNLK 1ST FOB in the DIC will be displayed.
5. Press and hold the lock and unlock buttons on the
first transmitter simultaneously for five seconds.
6. When a transmitter is learned (matched), the DIC
will display FOB LEARNED and then prompt you
to learn the second transmitter.
7. Repeat Steps 5 and 6 for the third transmitter.
8. Remove the key from the ignition.
The programming mode will shut off if any of following
has occurred:
 You don’t program any transmitters for two minutes.
 You take the key out of the ignition.
 You have programmed three transmitters.
Old Jan 11, 2017 | 10:22 PM
Dahc's Avatar
Dahc
27 fuse is good. Put a new one in to be sure. I still get no comm on rfa. When i reconnected the battery do you think it could of blew the receiver? The receiver is only a couple months old. The original one went bad. That is why i put the newer one in.
Old Jan 11, 2017 | 10:24 PM
Dahc's Avatar
Dahc
has occurred:
when i get to fob training it will not go any further.
Old Jan 11, 2017 | 10:55 PM
Dahc's Avatar
Dahc
I will check the voltage tomorrow.Thks
Old Jan 12, 2017 | 11:14 AM
Dahc's Avatar
Dahc
The only other code was radio no comm but I have an aftermarket radio so I think that is normal
Old Jan 12, 2017 | 01:10 PM
Dahc's Avatar
Dahc
In the programing instructions it says to have radio off. Will my aftermarket radio cause any problems?
Old Jan 12, 2017 | 06:31 PM
Dahc's Avatar
Dahc
Full voltage on orange wire. Do you think I blew the receiver when reconnecting the battery?
Old Jan 12, 2017 | 07:30 PM
Dahc's Avatar
Dahc
Originally Posted by 8VETTE7
The instructions in my owners manual (04) do not say anything about having the radio OFF. I also checked the owners manual for the earlier year cars and they also do not mention having the radio OFF. So not sure where you got that info........
I cannot imagine that any radio operating within its proper design frequencies would have an impact on the operation or programming of the keyless remotes.
The directions i have say turn the ignition to on. Turn the radio off. I dont remember where i printed them from.
Old Jan 12, 2017 | 08:14 PM
Dahc's Avatar
Dahc
I have already cleaned the grounds. The original receiver was bad. When it went bad it created a bunch of weird issues. It took forever to figure it out. I am not getting any weird issues like before. Is there a way to test the receiver?
Old Jan 12, 2017 | 09:09 PM
Dahc's Avatar
Dahc
I checked the ground wire on the receiver and voltage was good. I decided to hook the receiver back up and what do you know it started working. I was able to program my fob. Thanks for all the help.
Old Jan 12, 2017 | 10:03 PM
Dahc's Avatar
Dahc
I have been through the grounds and the star connectors.
Old Jan 13, 2017 | 06:39 PM
Dahc's Avatar
Dahc
I tried to use the fob today with no luck. I unplugged receiver then waited 5 min. then plugged back in. It started working again. Only for about a min. then stopped working again. What should i do next. Grounds and star connector have all been cleaned about 6 months ago. Only wire i have not tracked down would be the orange wire. Its weird because it has worked great until i disconnected the battery. Battery is optima red top 6 months old.
Old Jan 13, 2017 | 08:43 PM
Dahc's Avatar
Dahc
I will try replacing the rfa and see what happens...........
Old Jan 14, 2017 | 10:27 AM
Dahc's Avatar
Dahc
I have a new replacement receiver coming. If i have the same problem with the new receiver what do you think i should do next?when you say circuit problem what would you look at next.
To fob reprograming
Old Jan 14, 2017 | 10:46 AM
Pounder's Avatar
Pounder
1/4 mile/AutoX
bad BCM ????
Old Jan 14, 2017 | 11:35 AM
Dahc's Avatar
Dahc
If it was a bad bcm would you see some other issues? Can the bcm be tested?
Old Jan 14, 2017 | 12:27 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
Maybe with a Tech 2 scanner ?? here is a page out of the service manual, maybe this can help you. (do with patience)
File Type: pdf
