Went on a road trip last week to see my family about 180 miles each way. On the return trip I made it about 20 miles from home and the car started missing very badly. I get a buddy with an enclosed to come pick me up. When I get around to looking at it the next day I realized that it was on running on the front 4 cyls. As in 1,3 and 2,4. The rear header tubes were cold while the fronts were hot. Checked the plugs and pulled the valve covers and all looks good. Is this some odd grounding issue possibly? Any input is much appreciated.
The coils are fused to either bank. I.E. 1357 or 2468. So, its not a coil power issue. Its easy to check if you have spark.
Fuel injectors are supplied the same way and fired by the PCM.
IF,,,,,,, you have cylinders that are not firing in each bank and adjacent to each other, you either broke the cam or have a broken valve spring on one of those cylinders and a valve is staying open.
Pull the valve covers and see if you have valve train action on all the valves.
You mentioned that you pulled valve covers and did not find any problems, you could have a loss of a ground connection effecting only the 4 rear cylinders. One thing if possible is to be able to verify if the PCM is sending the signal to those coil packs, and of course you can always pull the spark plug wires and check for spark.
