Flashing dash lights
Old Jan 22, 2017 | 10:38 AM
Tomm1011's Avatar
Tomm1011
Default Flashing dash lights
Turn key on :
dash lights begin flashing, turn signal indicators lightup, turn parking lights on, flashing stops but turn indicators stay lit. Turn signal fail to work correctly, radio shows err, remove key all stops. Try to lock doors with fob sets off alarm. For some unknown reasons while driving all goes back to normal.
1. What causes this.
2.what will correct this?
3.where is the best place to begin?
Thanks.
Old Jan 22, 2017 | 12:50 PM
momo20's Avatar
momo20
mine is doing the same thing atm...replaced the battery nuts and torque downed to correct setting and that fixed my flashing dash lights issue...tested my alt. and found out it was failing so it's getting replaced. still have the the solid right turn lamb and when locking doors with fob sets off the alarm...so curious to see what fix you come up with as well
Old Jan 24, 2017 | 02:28 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Originally Posted by 8VETTE7
Battery and battery connections including the one at the starter would be an excellent place to start.
100% SPOT ON RECOMMENDATION! You MUST have a battery in circuit to filter out any alternator ripple. Your charging circuit is suspect and it needs a good inspection and most likely connection cleaning/tightening.
Here is the schematic that you need to have a firm grip on how its all connected::
There is also a engine ground connection and chassis ground connection that you should examine G-104/108 Chassis ground on the frame inboard the of the battery. Just follow the smaller ground wire on the NEG battery cable to the frame.
G-106 is the engine ground terminal on the block above the starter.
EARLY C5 97-98 schematic:
99-2004 Schematic:
Old Jan 24, 2017 | 02:49 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
G-104/108 Under that plastic battery surround tab:
G-106 Engine Block:
Starter solenoid connections:
Old Jan 24, 2017 | 03:41 PM
Tomm1011's Avatar
Tomm1011
G-106 Engine Block:
Thanks Bill, You are the man.
Tom, P.S. no codes showing
Old Feb 4, 2017 | 03:12 PM
Tomm1011's Avatar
Tomm1011
Originally Posted by Tomm1011
Turn key on :
Thanks.
cm
​​​​​​cleaned grounds as shown, now have constant malfunction. Replaced hazard switch, no change. I noticed when parking lights are on FOB functions properly, no alarm. Parking lights off, lock doors with FOB sets off alarm.
codes showing: 40 BCM B2578 B2583,
Old Feb 4, 2017 | 06:45 PM
Tomm1011's Avatar
Tomm1011
Default Engine not running, dash lights flashing
99-2004 Schematic:
alternator makes 14.2 v when charging, goes to 13.8 while driving.
Old Feb 7, 2017 | 06:45 PM
Tomm1011's Avatar
Tomm1011
Default Test drive
Cleaned G102 and all is good.After 30 mile test drive , back to turn signal malfunction and flashing dash lights.
Where to next?
Codes showing 40 BCM 2578 , 2583.
SHORT to power ?
Old Feb 11, 2017 | 04:54 PM
Tomm1011's Avatar
Tomm1011
Default G102
Turn key on :
Thanks.
Sat, 2/11/2017
Re cleaned and retightened G 102( rt.frt.) frame . Lights stopped blinking, signals all work. Cleared codes, no codes on retry. All is good.
Old Jan 6, 2023 | 04:36 PM
CptnAhab1's Avatar
CptnAhab1
3rd Gear
Sat, 2/11/2017
hey there! Found this and I have a similar issue, where is g-102, or do you mean g-104?
Old Jan 6, 2023 | 04:42 PM
mmartinez's Avatar
mmartinez
I don't belive you will get any reply as this will be a 6 year old thread, best thing to do is open a new thread.
Old Jan 6, 2023 | 05:21 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Yes, please start a NEW thread letting us know exactly what you’re seeing…also edit your profile to include model year, mods, tune etc…more we know about your car the better !!
To Flashing dash lights
