Please help - won't start - code pcm 0410C
Old Jan 24, 2017 | 02:38 PM
ArrestMeRed's Avatar
ArrestMeRed
Default Please help - won't start - code pcm 0410C
Car didn't want to start at home. Never done this before. After several tries car started and ran great. Drove it 40 miles and pulled in to get car inspected. Now it won't start and says pcm 0410C. Checked fuses and relays to air pump and fuel pump. Appears to be fine. Acts like it's not getting fuel. Shop doesn't have a clue nor do I want them working on it.
Old Jan 24, 2017 | 02:46 PM
KOZ's Avatar
KOZ
The secondary Air system will have no effect on starting.
Start with the basics, fuel, air, fire.
Old Jan 24, 2017 | 02:59 PM
ArrestMeRed
Thank you KOZ.
Any other ideas?
Old Jan 24, 2017 | 03:09 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
CALL ME ASAP!!!
PM sent!
Old Jan 24, 2017 | 03:54 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
HA! NO FUEL,,, BAD Fuel Pump RELAY
Here is the picture of the AIR Pump and the Pump outlet valve located under the drivers side headlight module>
Outlet valve disconnected for air flow test:
He still needs to fix the P-410 to pass emissions.
BC
ArrestMeRed
Thank you Bill Curlee. You are the man! Ended up being a bad fuel pump Micro Relay.
Old Jan 24, 2017 | 08:27 PM
ArrestMeRed
Thanks again Bill and KOZ for your help!
Replaced Micro Relay for Air Pump as well. Cleared P 0410 C code before I found out that I shouldn't clear P codes. Then drove the car about 20 miles, stopped for gas, headed for home and checked for codes. Not sure if it should have or not, but in @ 45 minutes of driving, it did not throw the 0410 code again. Not sure what this means but I hope it is a good thing???
Old Jan 25, 2017 | 07:57 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If you fixed P-0410, you will know for sure after a cold start. The PCM does not know if the A.I.R. pump is good until it commands the pump to run.
That run command would be immediately at cold start OR during part throttle cruise when a bunch of other conditions are met. If you didnt meet all those conditions during your trip home, the DTC would have remained off.
Drive it again today and report back the results. Good luck.
Bill
Old Jan 26, 2017 | 10:51 AM
ArrestMeRed
Checked the air pump on a cold start yesterday morning per Bill (the man) Curlee. Worked great - lots of air blowing. Drove it around yesterday with some highway driving and a couple of errand stops. Took it in for inspection and it passed with flying colors. Now just have to give the state their pound of flesh (tag and taxes). Thank you to all for your help - Mike
To Please help - won't start - code pcm 0410C
