Help with clutch needed
Old Jan 30, 2017 | 04:31 PM
usgecko's Avatar
usgecko
St. Jude Donor '13,'14
Default Help with clutch needed
I have a 2003 Z06, no modifications 25k miles, original clutch.
I have been experiencing a problem with the clutch which is getting worse.
I have followed the Ranger method in the past so clutch fluid is clean but I am experiencing the pedal sticking before it comes fully back up (sticks at about 1 inch or so from top). This is not after running the car hard but has been happening increasingly. Originally it seemed to be worse when car was cold and when it warmed up seemed to get better and the clutch seemed to be operating normally but it's pretty much happening constantly now.
No apparent leaks.
Any suggestions?
Thanks!
Stuart
Old Jan 30, 2017 | 07:00 PM
usgecko's Avatar
usgecko
Anyone?
Old Jan 30, 2017 | 08:09 PM
frodo84's Avatar
frodo84
Uneducated autodidact
Bleed the master and slave, if no results replace master. If no results, replace slave. That's the only answer I can give based on your assertion that this doesn't only happen when you run it hard. Good luck!
Old Jan 30, 2017 | 09:30 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
100% AGREE!!
You can also attempt to do a complete system bleed at the slave cylinder bleed ****. Its a ROYAL PITA but it may help get ALL the old fluid out and any air that might be trapped in the slave.
Bill
Old Jan 31, 2017 | 12:15 PM
usgecko's Avatar
usgecko
Thanks for the responses guys, i'm assuming this is going to be something pricey to get done (I don't have the skills or facilities to do it myself).
Old Jan 31, 2017 | 08:16 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
ABSOFRIGGENLOOTLY! It can get real expensive. 75-100 bucks an hour PLUS PARTS!
Maybe you can find a C5 FRIEND in your area that can "HELP" you do the job.
That way you can learn about your car and save a LOT of cash.
BC
Old Feb 3, 2017 | 07:43 PM
Paul 75 L82's Avatar
Paul 75 L82
Go to your local car shows and ask around and you will find someone or a local hot rod shop that will be a fair price.
To Help with clutch needed
