Driver side door lock won't lock
Old Feb 2, 2017 | 09:16 AM
screed's Avatar
screed
2nd Gear
Default Driver side door lock won't lock
I have a 1998 convertible. When using the power switch and key fob to unlock the doors everything works fine. When I try to lock the doors with either method the driver door will not lock. Any ideas on howto fix where the driver door will lock will be appreciated.
Old Feb 2, 2017 | 10:37 AM
screed's Avatar
screed
2nd Gear
Default Thank you 8VETTE7
Originally Posted by 8VETTE7
VERY common C5 issue.
Relays on the Door Control Module. You can replace them yourself or use a company that will provide a DCM with already replaced relays:
https://www.corvetteforum.com/forums...post1587396862
Bottom relay is LOCK next one up is UNLOCK
One company that provide repaired DCM's is:
www.autoclockrepair.com
Check the big auction site for others.
Thank you 8VETTE7
