Ranger clutch bleeding?
I did one drain and fill and pumped the pedal 25 times and checked it and it looked like nothing had changed colorwise. I pumped it another 60 times and I still can't see it did anything and I know there has to be a lot more dirty fluid in there. I'm gonna drive it a little and keep pumping it and checking but it looks like to me this is just a waste of time at this point and will probably be going underneath to bleed it.
Is it possible to install that remote bleeder option with just the tunnel cover off or do you actualy have to pull the trans and clutch.
I just want clean fluid
It worked 1-2x pumping the clutch. Now I just drive it for the day and then go back and replace the clutch fluid. I couldnt get the fluid turned over enough by just pumping the pedal.
Does yours change change color some after driving, man I don't want to tear all that stuff out and possibly not get all the air out if I have to bleed it. I know how much of a pain in the *** that can be.
I have not installed the Tick remote clutch bleeder but many who have seem to be satisfied.
https://www.corvetteforum.com/forums...h-bleeder.html
I think from all the pumping it would take in one day to get everything out of the whole system you would most likely have to replace the master cyl. and possibly slave too from the excess wear just placed on it. Wouldn't that suck!
At least at that point a person would know they have fresh fluid now though.
Again this is just based on my "No Vette Experience" but have worked on vehicles for over 50 years.
But please if there are any of the {Experienced} people out there that have been doing this and know for sure this Ranger thing eventualy works please chime in and tell me because I really don't want to do it the hard way. But at this point common sense just tells me it doesn't from just the first 2 attempts I've already done like this.
a real bleed is more efficient yes but this car is hard to bleed because of the location of the slave
the ranger method does not work in a day which is what throws people. you need hundreds and hundreds of cycles and while driving. hot/cold/static/moving.
driving in rush hour traffic is great with so much stop and go. my car improved greatly after buying around 3000 miles later doing this every tank of gas after the initial
I read somewhere it said that fluid Circulates between the slave and the mcl, does it actualy circulate or is it just pushed in and out of the slave.
I haven't seen these pieces yet up close but can you actualy completely flush both parts together or even separately?
That's the part I am most concerned about because of the difficulty of changing it and my clutch is fine and with my driving style I doubt I'll probably never tear it up and I damn sure don't want to do it for just the slave cyl..
1. Pop the end clip off the pivot rod that connects the MC piston rod to the pedal.
2. Push the pivot rod out.
3. Rotate the clutch MC 1/4 CCW (I think, going from memory here... you'll figure it out) to release it from the firewall
4. Push the release collar down on the pressure line's quick-connect and pop it apart from the slave line
And you're done! If you have strong fingers, you can actually do all of the above without tools. (mind blown, right?)
Optionally if you're replacing the reservoir, then unscrew it from the firewall or just pop the hose out of the MC if not.
