help with calipers
Old Sep 22, 2002 | 08:32 PM
ydeer's Avatar
ydeer
Default help with calipers
i have replacement z06 calipers on my 2000vert. my problem is that i have 14" eradispeed rotors on rear and the caliper is only contacting half of the rotor. i have 19" hres on the rear. would anyone know if i can install the z06 front calipers on the rear and if so what would it involve.(special brackets or whatever???)
Old Sep 23, 2002 | 09:07 PM
CHJ In Virginia's Avatar
CHJ In Virginia
Default Re: help with calipers (ydeer)
The mounting bolt spacing is different and would require a special bridge. Do a topic search, I think that I remember someone making a bridge or adaptor for their car. There is also the proportioning problem caused by using the larger caliper on the rear. It will cause problems with the ABS. Not really a recommended mod.
