Starter Does Not Engage
Old Feb 7, 2017 | 05:46 AM
jj_adams319's Avatar
jj_adams319
Default Starter Does Not Engage
Car is a 1998 MN6 Coupe
The issue is the starter spins but does not engage to the flywheel.
I swapped out the starter and trouble persists.
Could there be something electrical that is not letting the starter engage
the flywheel?
No check engine light.
No BCM codes.
Hit both solenoid and starter with hammer, no help.
Removed TDR and jumped red to purple, same result.
Help is much appreciated.
Jason
Old Feb 7, 2017 | 11:24 AM
mmartinez's Avatar
mmartinez
Sounds like your starter is not engaging the fly wheel. Its not an electrical problem, when the solenoid is energized it moves the starter drive gear forward to engage the fly wheel while simultaneously the high current contacts provide power to the starter motor. It's a possibility that the starter you installed could have a bad starter drive, or as mentioned in earlier post that maybe your flywheel has some broken/missing teeth. Hope this helps.
Old Feb 7, 2017 | 03:33 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Bud,, the last time I had this issue,, THIS is what I discovered!
I PRAY it isn't your issue!!
Old Feb 8, 2017 | 12:42 AM
jj_adams319
BC, thats ugly and not my issue.
Visual inspection was good.
I just wanted to get a consensus to see if trouble was mechanical or
electrical.
I agree it sounds mechanical.
I get to pull the header and xpipe again. yay me!
Old Feb 8, 2017 | 01:27 AM
Rob 02's Avatar
Rob 02
Hitting the starter with a hammer can break the permanent magnets loose. You can ruin a good starter that way.
Old Feb 8, 2017 | 02:08 AM
Rob 02's Avatar
Rob 02
8Vette7 is the resident expert on electrical.
This may give you a visual on the connections he mentioned.
Old Feb 8, 2017 | 02:57 AM
Rob 02's Avatar
Rob 02
The starter has a Bendix spring where the gear comes out of the hole and engages the fly wheel. When the starter spins the gear springs out on a twisted shaft.
Either:
A. The starter isn't spinning fast enough to throw that gear out. not enough voltage. Charge the battery.
B. It got wet and rusty from being near the road and it needs some lube.
Spray some WD40, PB blaster or KY through a red straw inside the plastic cover nearest the starter gear.
Remove the plastic cover by the starter and grease the starter gear.
To Starter Does Not Engage
