abs/tc code c1225 fixed
Old Feb 11, 2017 | 09:42 PM
99bluvet's Avatar
99bluvet
Default abs/tc code c1225 fixed
After many months and many dollars, I have finally had success with my intermittent abs/tc lights. I put some dielectric grease on the connectors between the wheel hub and the jumper wire and have not had even one abs/tc light since then. I have travelled over 1500 miles, city and highway, over the last 4-5 weeks. For any of you with similar problems, I hope this may help you.
Old Feb 13, 2017 | 06:57 PM
FASTFATBOY's Avatar
FASTFATBOY
This is a LR wheel sensor code? I had this code when on bumpy roads and RR tracks.
I closed up the female sides of the connectors at the hub with a pick and mine went away.
Old Jan 28, 2019 | 08:28 AM
turabo87's Avatar
turabo87
Dang, I'm going to try this tonight!!! I hope I fix my C1225 code with this.
To abs/tc code c1225 fixed
