Active handling warming up????
Old Sep 23, 2002 | 11:28 AM
jimman's Avatar
jimman
Default Active handling warming up????
This is a new one and happened the other morning, is this normal?
Old Sep 23, 2002 | 11:46 AM
Casper001's Avatar
Casper001
Default Re: Active handling warming up???? (jimman)
Yes, I get this often when leaving work out of my parking garage. If you make a turn in the car within the first 30 seconds or so of driving you will get this msg.
Old Sep 23, 2002 | 01:01 PM
vettenuts's Avatar
vettenuts
Default Re: Active handling warming up???? (timbrwolf9)
I also think if you run under a certain speed for so many seconds of starting it will come on. I get it a lot because of where I live.
Old Sep 23, 2002 | 01:30 PM
jerryv's Avatar
jerryv
It's normal as long as you get a 'Warm up Complete' message a few seconds later.
Old Sep 23, 2002 | 01:40 PM
jimman's Avatar
jimman
Default Re: Active handling warming up???? (vettenuts)
Thanks for the info
Old Sep 23, 2002 | 02:52 PM
Paul R's Avatar
Paul R
Cruise-In I Veteran
Cruise-In II Veteran
This message comes up if you do any maneuver before the active handling has calibrated. A sharp turn, hitting a speed bump, anything where the computer needs to check the active handling sensors. The active handling calibrates itself after initial startup by resetting the sensors when the car is driven in a relative straight line for a set period of time (I think it is about 10 seconds). If the warming up message comes up, the warm-up complete message will come on once calibration is complete.
BTW, this is normal, as stated above.
To Active handling warming up????
