Cam Install Question???
Old Sep 23, 2002 | 08:10 PM
hrdtopv8's Avatar
hrdtopv8
Default Cam Install Question???
When replacing valve springs, what is the best way to keep the valves from falling in the piston chamber? Also, is there play between the pushrods and rocker? :confused: Thanks for info.. :chevy :seeya
Old Sep 24, 2002 | 12:22 AM
lost's Avatar
lost
Default Re: Cam Install Question??? (hrdtopv8)
If you have a compressor, there is a fitting that goes in the sparkplug hole, also a magnetic tool, or if your like me( dirt poor) you get a friend to hold the valve while you change the springs and install the keepers.There is no play between the push rods and the rocker. On a solid lifter cam there is a lash adjustment between the rocker and the top of the valve stem. On a hydraulic cam , you preload the lifters....
Old Sep 24, 2002 | 12:36 AM
jmX's Avatar
jmX
Default Re: Cam Install Question??? (lost)
What he said. I've always used the air compressor method to pump up the cylinder and hold the valve up.
Old Sep 28, 2002 | 12:45 PM
Black Magic's Avatar
Black Magic
How the heck do you hold the valve with your fingers while you're trying to put the spring on?? :confused:
Old Sep 28, 2002 | 01:26 PM
CJS's Avatar
CJS
On another forum I have read posts of threading nylon rope into the spark hole, then bringing that cylinder to TDC and the rope compresses in the chamber and holds the valve up.
To Cam Install Question???
