Intake Manifold Removal (How To!!!!)
Old Feb 24, 2017 | 06:44 AM
RAiN 1999's Avatar
RAiN 1999
Default Intake Manifold Removal (How To!!!!)
I have a small oil leak coming from my oil sending unit but in the process I need to clean out and replace gaskets on my intake manifold. I want to remove the manifold but not the fuel injectors.... I need precise instructions on how to remove the intake manifold pls. C5 2004
Old Feb 24, 2017 | 07:08 AM
TOPCATHR's Avatar
TOPCATHR
Search, there are some excellent threads...good luck
Old Feb 24, 2017 | 07:32 AM
tbrowne's Avatar
tbrowne
Try this link. It's not difficult - just be sure you have a fuel line disconnect tool on hand before you start.
http://ls1tech.com/forums/corvette-p...-corvette.html
Old Feb 24, 2017 | 07:35 AM
vettenuts's Avatar
vettenuts
And use a very strong vacuum cleaner to get around the manifold prior to removal. A lot of fine sand seems to collect and when you pull it can fall into the intake ports of the heads. Vacuum the intake ports once the manifold is off as well.
As I recall, manifold needs to be removed and installed with the rear two bolts inserted so make a split rubber hose to hold them up until the manifold is in position.
Old Feb 24, 2017 | 07:45 AM
RAiN 1999's Avatar
RAiN 1999
Thx I will definitely use a strong vacuum cleaner and an air hose to air hose to blow out and get everything loose and then vacuum it all up really good and as I am removing
Old Feb 24, 2017 | 09:04 AM
huesmann's Avatar
huesmann
Here are a couple more how-tos:
http://www.peakspeedshop.com/removal.xhtml
http://www.vette747.com/index.php/en...intake-removal
Old Feb 24, 2017 | 09:39 AM
RAiN 1999's Avatar
RAiN 1999
Huesmann just what I'm looking for ..... Thx a million gotta give old baby a good spring cleaning.
Old Feb 24, 2017 | 03:00 PM
RAiN 1999's Avatar
RAiN 1999
Thx tbtowne 💯💯💯 great instructions and pics !!!!
Old Feb 24, 2017 | 03:06 PM
RAiN 1999's Avatar
RAiN 1999
That's why I love Corvette Forum .... Just ask for help and decent members give such precise advice we can screw the dealership or rip off garage around the corner and down the street every time !!!!!!
Thx members
Old Feb 24, 2017 | 03:41 PM
v6turbo87's Avatar
v6turbo87
Here is yet another however this one says to drain the coolant and THAT IS NOT NEEDED:
http://ls1tech.com/forums/generation...n-dummies.html
Old Feb 24, 2017 | 03:52 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
just in case you want to relocate the sender (I recommend)
File Type: pdf
File Type: pdf
File Type: pdf
To Intake Manifold Removal (How To!!!!)
